Designing a Solar Water Heater System for 4500 Gal Tank
The discussion focuses on designing a solar water heater system to maintain a 4500-gallon tank at 140°F. The calculation reveals that 67,230 BTU/h of energy is required to compensate for the tank's heat loss of 1.8°F per hour. To determine the necessary collector area and efficiency of solar collectors, users are encouraged to utilize online solar water heater calculators, such as the one provided at Infinite Power.
  • Understanding of thermal energy calculations
  • Familiarity with solar collector efficiency metrics
  • Knowledge of BTU (British Thermal Unit) measurements
  • Basic principles of heat transfer
  • Research solar collector area requirements for heating systems
  • Explore solar water heater efficiency ratings and comparisons
  • Learn about thermal energy storage solutions for large tanks
  • Investigate advanced solar water heater design techniques
Engineers, renewable energy enthusiasts, and homeowners interested in designing efficient solar water heating systems for large water tanks.
gideon0223
The problem is designing a solar water heater system to keep a 4500 gal tank of water at 140F during the day.
The tank in question has the following properties:
5000gal Volume
4500gal water
It loses about 1.8 degrees F/hr if not heated.
I first need to figure out amount of energy needed to maintain temps.
I did this using the following math:
4500gal of solution times 8.3 lbs/gal of water = 37350lbs of solution
37350 * 1.8 = 67,230 BTU/h of energy needed.
Seems pretty straight forward so far? (Math Errors?)
How do I go about finding out how much collector area and efficiency of solar collectors and heat transfer?
I googled solar water heater calculator, and got lots of good hits. Here's one of the first ones:
http://www.infinitepower.org/calc_waterheating.htm
You can use a similar google search to find other calculators if that one isn't exactly what you are looking for.
Welcome to the PF, BTW!
15K
