Projectile motion (the dreaded volleyball problem)
The discussion revolves around a projectile motion problem involving a volleyball player striking the ball over a net. The problem specifies the dimensions of a volleyball court and the height of the net, along with the initial height and angle of the ball's trajectory. Participants are tasked with calculating various parameters such as initial velocity, maximum height, and other related aspects of the ball's motion.
  • Mixed
  • Participants explore the use of kinematic equations to analyze the projectile motion, discussing the setup of the problem and the necessary calculations for both horizontal and vertical components of motion.
  • Some participants question the correct interpretation of height in relation to the net and the initial height of the ball.
  • There are attempts to clarify the time of flight and the relationship between initial velocity components and the overall motion of the ball.
  • Several participants express uncertainty about their calculations and seek verification of their approaches.
The discussion is ongoing, with participants sharing their calculations and seeking feedback on their reasoning. Some have received guidance on correcting their setups, particularly regarding the interpretation of height and the application of kinematic equations. There is a mix of correct and incorrect calculations being presented, indicating a collaborative effort to refine understanding.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for the calculations. There is a focus on ensuring that the initial conditions and parameters are accurately represented in their equations.
boomer77
A regulation volleyball court is L = 18.0 m long and a regulation volleyball net is d = 2.43 m high. A volleyball player strikes the ball a height h = 1.81 m directly above the back line, and the ball's initial velocity makes an angle theta = 48° with respect to the ground
find:
a.) vi the ball must be hit at to barely make it over the net
b.)the maximum height reached by the ball in this case
c.)vi for the ball to be hit so it directly lands on the opponent's back sideline
d.) the maximum height for the ball in this case
e.)maximum vi for the ball to barely make it over the net and just barely land in bounds
(for the contact point in previous problems, what is the maximum vi)
f.)if you hit the ball at this maximum vi, what angle should you hit it at?
d=vt for the x direction
free fall equations for the y direction
~i know the answer to a is 9.73 m/s what will i do with this in part b?
~for b. i would like to know how to set up this problem
correct any errors for this question please
dx=9.0m
vx= ?
t=9.0/vcos48
dy= 0.62m because it it hit i.81m above the ground
viy= ?
a=-9.8 m/s^2
~part c is basically like part a but dx is 18.0m and i believe your dy is 2.43
~i think part d is like part b
and i haven't tried part e or f so help will be of great appreciation! thanks to anyone who replies!
What is the general formula for height (vertical distance) for a freely falling object (and watch the initial values, at t = 0).
At what time does it reach the highest point (what happens to the vertical velocity?).
The best way to do these problems is create a chart. Then from the chart, use some basic ideas and then apply the three basic equations for kinematics.
The way you setup the chart should look like this, where o (naught) means initial. Such as xo means initial position along the x-axis.
http://students.washington.edu/angelofg/pictures/chart.jpg
Things to remember: there is usually no acceleration in the x-direction, and in the y-direction will usually be gravity. Time will be the same for both.
On a side note as well, the initial velocity will be the same for both. However, it will be a component. Since we've broke the vector up into x and y components we have V*cos(theta), and V*sin(theta) =). I will leave you to figure out which one goes to which.
The three equations are:
v = vo + at, x = xo + volt + (at^2)/2, and v^2 = vo^2 + 2*a*(x - xo). From here on, it's just algebra.
~for part a the question was "at which initial speed must the player hit the ball so that it just barely makes it over the net?"
my work is as follows:
dx= 9.0
vx= vcos48=> .669
t= 9/v(.669)
dy=0.62m taking into account the height in which it was hit at
viy= vsin48=> .743
a=-9.8
d=vit+1/2at^2
.62= .669(12.11)-4.9(12.11/v)^2
-7.48=-718.6/v^2
v^2=96.06
v=9.73
my answer was correct
~for part b the question states "what is the maximum height above the court reached by the ball in this case?"
my work looked like this:
dx=9.0
vx= 9.73(.669)=> 6.51
t= 1.38
dy=?
viy= 9.73(.743)=> 7.23
vf=0
a=-9.8
vf^2=vi^2+2ad
0^2= 7.23^2+2(-9.8)(d)
-52.27= -19.6(d)
d= 2.66
i put this answer into my problem set and i also added this to the height of the net and it says my answer is wrong
~part c asks "at what initial speed mut the ball be hit so that it lands directly on the opponent's back line?"
i went about the problem just like part a but changed my dx to 18.0m and my dy to 2.43m giving me an answer of 14.44 and my problem set says it is wrong
could you explain why these answers are wrong?
dx=9.0
t= 1.38
Here you found the time to reach the net, which is not needed.
dy=?
vf=0
a=-9.8
vf^2=vi^2+2ad
-52.27= -19.6(d)
d= 2.66
This looks OK.
Why add the height of the net? Add the initial height of the ball.
I don't know anything about volleyball, but I assume the back sideline is at the other end of the court. Again, you used the height of the net instead of the initial height of the ball.
ok so for part b my answer is now 4.47
for part c my problem should look like this
dx=18
vx=vcos48
t=26.9
dy=0
viy=vsin48
a=-9.8
then use d=vit+1/2at^2?
i mean dy=1.81 (whoops
boomer77 said:
dx=18
vx=vcos48
t=26.9
You mean: t = 26.9/v
dy=0
viy=vsin48
a=-9.8
Yes, except that dy ≠ 0.
that dy = 1.81 or is it negative?
It's negative.
so here's my new work:
d=vit+1/2at^2
1.81= vsin48(26.9/v)-4.9(26.9/v)^2
1.81=19.99-(3545.7/v^2)
-18.1=-3545.7/v^2
v^2=195.9
v=13.99
my problem set is saying this answer is wrong, is there a flaw in my math?
wait nevermind i didn't make that negative
this is my new work
-1.81=vsin48(26.9/v)-4.9(26.9/v)^2
-1.81=19.9-(3545.7/v^2)
-21.8=-3545.7/v^2
v^2=162.64
v=12.75
ok so for part d i have to find the maximum height the ball will reach in this case so my work will be:
vf^2=vi^2+2ad
0=12.75^2+2(-9.8)d
-162.6=-19.6d
divided by -19.6
d=8.29
8.29+1.81
d=10.01
...but it is wrong, and i don't know why
vf^2=vi^2+2ad
0=12.75^2+2(-9.8)d
-162.6=-19.6d
divided by -19.6
d=8.29
8.29+1.81
d=10.01
Use the vertical component of the velocity.
  • · Replies 19 ·
14K
  • · Replies 39 ·
  • · Replies 21 ·
  • · Replies 22 ·
12K
