Thread Closed
Charged Particles
Share Thread Thread Tools
Dec31-08, 02:38 PM   #1
Charged Particles
I'm hating Electromag as of late. To the extent I can't even understand these 'simplest' of questions. I don't want anyone to be doing my work for me as nothing is essentially accomplished that way. If someone could head me in the right direction with these questions, I'd be most grateful.
[/URL]
My answers (using some rudimentary calculation) came to:
i) c - [-30v]
Further away than y and therefore more negative but not by much thus -30v, this does not provide enough substantial evidence of mathematical precision, rather just a logical guess.
ii) a - [surface charge density is constant]
iii) b - [zero potential]
iv) d - [2.3 x 10^29]
v) c - [other forces]
Kind Regards,
Billy
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jan1-09, 02:33 PM   #2
Bump - Can anyone help me on this?
Regards,
Billy
Jan1-09, 02:43 PM   #3
Hello Billy246
Well i) is simple if you just use V = kq/r, or 1/(4pi epsilon) * q/r, whichever notation you like. Now, you got ii) right, but can you prove your answer? (Hint: use Gauss's Law) Try looking at iii) again... does it HAVE to be at 0 potential?
I'll take a look at the rest a bit later... I'm in a bit of a hurry now, so until then, good luck!
Jan1-09, 05:43 PM   #4
Charged Particles
Thanks with this, your assistance is gratefully received. I don't want to appear pushy on these forums as it is other people's time being used.
Basically used your idea on
Part i
Potential = kq/r = [(8.99x10^9) x 30nC]/3
Then for charge point 2?
[(8.99x10^9) x -20nC]/root 13
add the two together to get ~40V
thus the answer is a)
Part ii
The answer I gave was only due to the logicality of it. I cannot provide an adequate reasoning for my answer.
Part iii
I was under the false impression that it must be at zero potential.
It must have something (this therefore rules out 'neither'), is the charged hollow sphere at a constant potential due to the constant surface charge density?
Kind Regards,
Billy
Jan1-09, 06:09 PM   #5
Quote by Billy246 View Post
Part i
Part ii
Part iii
Kind Regards,
Billy
Okay, so it looks like you got the first question right. Good job! For the next part, try to use Gauss's Law. If you haven't heard of this, then never mind... just know that whenever you have a conducting surface, the charge distributes itself over the surface such that *the net electric field within the conductor is ZERO.* This is absolutely essential, because we can't have currents present within a conductor for absolutely no reason.
Now, for the next part with potentials over a conducting surface, note that potentials are always relative to another. In other words, we only care about potential differences. So, stating that something is AT 0 V potential means absolutely nothing; this ONLY means something when you say that the potential at infinity (the potential really really really far away) is 0. Now, the answer is actually that the potential over the conducting surface is a constant. Try to see what happens if the potential across a conducting surface is NOT constant: if two areas have different potentials, then electrons will flow between them, causing a current! Eventually, everything becomes balanced, and no electrons flow, implying no potential differences across the surface of the conductor.
Does this make sense? If not, please say so, and I will try to help you better. Good luck, and happy new year!
Jan1-09, 06:24 PM   #6
Yes thank you, you have provided me with enough information to understand the first three question parts.
I have a problem visualising it all, my physics lies in space not charges!
If you could point me in the right direction for the final two parts I would be most thankful.
Thanks for your time and kindness.
Billy.
Jan2-09, 08:52 AM   #7
Kind Regards,
Billy
[Hi Billy I guess your at the uni of leicester as I have the exact same questions to do. I've got these answers so far
i) a
ii) a
iii) a
iv) c (1.8x10^29) - I got a different answer for this than what you got. How did you get your answer?
v) i'm not sure about this how did you come to your conclusion for this?
Thanks Ben]
Jan2-09, 09:02 AM   #8
Quote by Besh View Post
Kind Regards,
Billy
i) a
ii) a
iii) a
Thanks Ben]
Yeah I am, finding this paper tricky though.
As for parts iv and v, i'm fairly sure iv is wrong due to my highly crackpot calculations. I don't even think I have my 'working' anymore. I wouldn't submit the answer if I were unsure.
On v, I don't understand it but I thought other forces were in play, I don't know if it's ohmic or not :S
Looking at it now, the material must be ohmic as this proportionality comes from the fact that an applied electric field superimposes a small drift velocity on the free electrons in a metal.
Jan2-09, 09:23 AM   #9
I see what you mean. Tipler isn't being overly helpful but it kind of suggests the material being ohmic like you have suggested but what im not sure about is whether the answer could be (d) or (e)?? How have you found the ret of this paper and the others?
Jan2-09, 09:26 AM   #10
Read my pm, I can provide you with some help.
With part iv, i'm inclined to ask you for your working. How did you get to that value. And part v is a toss up between a,d,e :/
Maybe someone here can assist us with this.
Basically with iv)
(2.7 x 10^3)/27 = 100
100 x (2.7 x 10^3) x 6.02 x 10^23 = 1.625 x 10^29
~1.6 > b.
However not sure how to factor in the fact that there are 3 carriers per atom
Jan2-09, 09:37 AM   #11
well with the information given
Aluminium:
M = 27.0gm/mol = 0.027kg/mol
ro = 2.7 x10^3 kg/m3
N_a = 6.02 x10^23 (atoms)/mol (it doesnt tell you the atoms part but I think that might jus be seen as common sense if you did chem at a level)
first I calculated the mass of the Al atoms by:
mass = N_a/M = 2.23 x10^25 atoms/kg
then it says in the question there is 3 e- per atom so i multiplied the mass by three (called it mass_e)
mass_e = 6.69 x10^25 carriers/kg
Lastly the number of carriers in the wire (n) in that density =
n = ro x mass_e = 1.8 x10^29 carriers
I checked the units and they work out right.
Hope that helps.
Jan2-09, 09:41 AM   #12
I just read part V, and I think the answer is (C). Here is my reasoning (I may be overthinking the problem, but this is true): the problem doesn't state that the current is *immediately* steady, but is *quickly* steady. From this, we can observe that the voltage must increase from 0 to V at a very quick rate. Now, when we have an changing voltage, we have a changing electric field, which causes a changing magnetic field to exist, which causes another changing electric field to exist, which causes another changing magnetic field to exist, etc. Now all these fields (not only electric, but magnetic since the charged carriers always have non-zero velocity... use the Lorentz force) act on the charged carriers, so we have that there must be other forces exerted on the charge carriers besides that due to E.
The material actually does not have to be ohmic (meaning that is has resistance); if we have a thin wire which has magnetic fields on the edges such that electrons are always repelled and whose interior is a vacuum (minus our charge carriers within), for example, establishing a voltage difference still proves us with a steady current, and this wire is clearly not ohmic (in fact, it has zero resistance!).
As a more practical example, consider superfluids; they have no resistance, and are thus not ohmic, but we can still run steady currents (though extremely high) through them.
The other statements made cannot be directly deduced from the propositions made in the problem.
Good luck!
Jan2-09, 09:42 AM   #13
Yes that makes sense, thanks.
I never did chem at a-level.
Jan2-09, 09:44 AM   #14
Quote by Domnu View Post
Good luck!
WOW great answer it seems perfectly logical. Thanks
Jan2-09, 09:45 AM   #15
I found chem pretty boring and thats about the only knowledge ive used in physics so far so I wouldnt worry about not having done it.
Jan2-09, 09:46 AM   #16
You're welcome
Jan2-09, 09:49 AM   #17
You're welcome
Yes thank you very much.
Do you agree with Besh's answer for part iv?
I do however have some concerns over part v seeing as it seems you are over complicating the question. I'm thinking it may be answer e, due to the fact that I doubt they would introduce a non ohmic material at this level. Even stating it is a thin conducting wire.
Regards,
Billy
Thread Closed
Thread Tools
Similar Threads for: Charged Particles
Thread Forum Replies
charged particles Introductory Physics Homework 2
Charged particles Introductory Physics Homework 3
Charged Particles Introductory Physics Homework 7
Charged Particles High Energy, Nuclear, Particle Physics 3
Some Help! Charged particles Introductory Physics Homework 11
