Solving Equations of the Form Ax - By = 1
  • Context: Undergrad
  • Thread starter Thread starter soandos
    Form Solving equations
The discussion revolves around finding integer solutions to equations of the form Ax - By = 1, exploring methods for generating multiple solutions, and extending the conversation to similar equations involving three variables. Participants share examples, propose methods, and question the nature of the solutions.
  • Some participants note that there are infinitely many solutions to the equation Ax - By = 1 and inquire about methods to find these solutions.
  • One participant provides specific integer solutions and suggests they lie on a line with a slope of 19/17, while also noting that the solutions are not evenly spaced.
  • Another participant questions how to solve a related equation ax - by - cz = 1 for integer solutions and discusses the implications of the Euclidean algorithm.
  • There is a suggestion that integer solutions can be expressed in a general form involving parameters, but the specifics of this approach are debated.
  • One participant expresses uncertainty about the concepts discussed, indicating a lack of background in number theory and linear algebra.
  • A participant references a video resource that explains how to obtain all solutions, indicating a desire for further learning.
Participants do not reach a consensus on the methods for finding solutions or the nature of the solutions themselves. There are multiple competing views and ongoing questions regarding the general forms and spacing of solutions.
Some participants express uncertainty about the mathematical concepts involved, particularly regarding the general solution forms and the implications of the Euclidean algorithm in the context of integer solutions.
soandos
I know how the algorithm can be used to find a solution to an equation of the form
Ax - By = 1 where A and B are given.
I also know that there is more than one solution to this. how are the others found.
for example:
for 17x-11y=1
17=11+6
11=6+5
6=5+1
then reversing to get the coefficients (find how many times each one appears)
17-11-(11-(17-11))
yielding 2*17-3*11.
there are infinitely many more solutions to this.
Anyone know how they are found?
when i plotted the first hundred solutions they seemed linear, but that might be wrong.
Well, it is a linear system of equations consisting of one equation and two variables... Sure, only wanting the integer solutions is a wrinke, but are there any others?
yes for example
{244,377}
{1201,1856}
{1630,2519}
{3511,5426}
{5876,9081}
to the best of my knowledge they all lie on a line with a slope of 19/17
EDIT: also, does anyone know how to solve ax-by-cz...==1 for integer solutions only?
EDIT: While all of the solutions are on the line, they are not evenly spaced
EDIT: While they are not evenly spaced, the equation for the difference between spaces is
y=17/11x+0.
Well, it's a linear equation in three variables... What do the ideas behind the Euclidean algorithm give you?
You sure about that?
y=17/11x+0.
Right. And for what values of x will y be an integer? Can you write the general solution in the usual form
(x, y) = (a, b) + t (c, d)​
with the twist that a, b, c, d, t are all integers?
If [itex]x_1[/itex] and [itex]y_1[/itex] are integer solutions to ax+ by= c then so are [itex]x_n= x_1+ bn[/itex] and [itex]y_n= y_1- an[/itex], for n any integer, because a(x_1+ bn)+ b(y_1- an)= ax_1+ by_1+ abn- abn= ax_1+ by_1= c. It's only slightly harder to show that any integer solutions to that equation must be of that form.
thanks.
hurkyl:
ax-by-cz = d
I am not sure. i know that i can find the gcd of all three (just have to do it two at a time), and i know that i can find solutions with any two of the variables, but that does not get me the third.
is it possible to solve for any any two (make z zero), then solve it again for z = 1, and since it is linear in three variables can i just plot the line, and all solutions will be on that line?
with respect to the last part, i am not sure what you mean (i have never taken number theory)
In your linear algebra class, when you solve systems of equations, you often express the general answer in a form like
[tex] (x, y) = (2, 1/3) + t (1, -5/2)[/tex]
You can do the same thing with integer systems of equations, but with the added feature that everything in sight is an integer. (And done to ensure that no solutions would be missed)
sorry haven't taken that either.
just seen the algorithm somewhere are started messing with it.
(x,y) means what?
A little bit after half-way through this video, the prof. explains how to get all solutions. http://cmes.uccs.edu/Spring2008/Math311/Videos/Math311Lecture5.mov
And I learned a new way to do multiplication : P
12K
