Water & Steam Tables: Understanding Specific Density
  • Context: Undergrad
  • Thread starter Thread starter Micko
    Steam Water
This discussion focuses on understanding specific density in the context of water and steam tables, particularly at a pressure of 1 bar. Key terms include rhoW1, rhoD1, and rhoM1, which represent specific densities for liquid and gaseous phases, as well as a reference column. The user seeks clarification on the concept of specific density and its application in calculating steam density at 1 bar, with typical steam temperatures ranging from 220 to 300 °C and pressures around 150 bar. The conversation emphasizes the need for interpolation techniques in steam tables to derive accurate density values.
  • Understanding of specific density and its distinction from general density
  • Familiarity with steam tables and their application in thermodynamics
  • Knowledge of interpolation methods for data extraction
  • Basic concepts of phase changes in water (liquid and gaseous phases)
  • Research the properties of water and steam at various pressures using steam tables
  • Learn interpolation techniques for extracting specific density values from steam tables
  • Study the relationship between temperature, pressure, and specific density in thermodynamic systems
  • Explore the impact of ambient temperature on reference water column density
Engineers, thermodynamicists, and students studying fluid mechanics or boiler operations will benefit from this discussion, particularly those involved in calculating and optimizing steam and water properties in industrial applications.
Micko
Hello and Happy New Year to all,
I have found one formula which uses terms I hope you'll help me understand.
It is given in the attachment, and this is l
rhoW1 specific density [kg/m3] (corresponds to table value Pa = 1 bar, liquid phase)
rhoD1 specific density [kg/m3] (corresponds to table value Pa = 1 bar, gaseous phase)
rhoM1 Specific density [kg/m3] (corresponds to table value Pa = 1 bar, reference column)
rhoW Specific density [kg/m3] (interpolated value, liquid phase)
rhoS specific density [kg/m3] (interpolated values, gaseous phase)
rhoM specific density [kg/m3] (reference water column at ambient temperature)Now, there are terminology used here I don't understand.
1. Specific density. What is that? I know about density, but not sure what specific density is.
liquid phase (steam table) means saturated water and gaseous phase (steam table) means saturated steam.
2. What would be steam density at P = 1bar?
To give you more informations, these densities are corresponding to steam and water in steam drum in boiler.
Typical values: Temperature of steam from 220 to 300 °C, pressure is about 150 bar and temperature of reference column is about 40 °C.
Now can you help me and pint to water and steam tables to figure out what would be typical values of above mentioned densities?
Thank you
This looks like some sort of formula for interpolation in the steam tables, but, without additional context, it is really impossible to guess what is involved here.
24K
  • · Replies 44 ·
