| Thread Closed |
Simple Moment of Inertia Question |
Share Thread | Thread Tools |
| Jan2-09, 11:33 PM | #1 |
A rod of negligible mass is pivoted about one end. Masses can be attached to the rod at various positions along the rod. Currently, there is a mass (m) attached a distance (L) from the pivot. To increase the moment of inertia about the pivot by a factor of 5, you must attach... 2. Relevant equations I=mr^2 3. The attempt at a solution Io= mL^2 If= 5(Io) = mL^2(original mass)+4(mL^20) All I did was add four more masses of equal size at a distance L from the pivot. Is there another solution? |
| Jan3-09, 01:05 AM | #2 |
You are correct. The definition of moment of Inertia is [tex]\sum_{i} m_{i} r^{2}_{i}[/tex]
| Jan3-09, 06:36 AM | #3 |
Mentor
For example: What if you could only add a single mass of equal size. How could you solve the problem then? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simple Moment of Inertia Question
| Load Inertia - Mass Moment of Inertia Question | Mechanical Engineering | 2 | ||
| Simple Moment of Inertia problem | Introductory Physics Homework | 2 | ||
| Simple Moment of Inertia question | Introductory Physics Homework | 3 | ||
| Calculating Moment of Inertia for Simple Function | Introductory Physics Homework | 6 | ||
| What are moment of inertia, mass moment of inertia, and radius of gyration? | Introductory Physics Homework | 1 | ||
