How Much Delta-V is Needed for a Hohmann Transfer to Mars?
  • Thread starter Thread starter hhhmortal
    Orbits
The discussion revolves around estimating the total delta-V required for a Hohmann transfer between Earth and Mars, while considering the implications of planetary motion and the timing of return journeys. Participants are exploring the dynamics of interplanetary travel and the associated calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are attempting to understand the delta-V calculations for a Hohmann transfer while questioning the necessity of considering gravitational influences and planetary motion. There are discussions about the equations needed for calculating escape velocity and the synodic period of the planets.
Some participants have shared their approaches and equations used, while others are seeking clarification on when to apply specific equations. There is an ongoing exploration of the relationship between delta-V calculations and the timing of the transfer, with no explicit consensus reached yet.
Participants are navigating the constraints of the problem, including the assumption of circular orbits and the need to account for the motion of both planets during the transfer. There is also a focus on the minimum wait time at Mars before a return journey can commence.
hhhmortal
Estimate the total delta-V required to perform a Hohmann transfer between the Earth and Mars, ignoring the gravitational influences of the two planets. The planetary orbits may be assumed to be circular and in the same plane.
Why will there be a minimum wait time at Mars before a return journey to Earth, via a second Hohmann transfer, becomes possible?
v = [GM(2/r - 1/a)]^1/2
Is this more simple than I think it is, Do I need to link conic sections instead?
Thanks.
^Bump
So by ignoring the gravitational influences of the two planets, you're concerned strictly with the interplanetary orbit transfer, I assume.
Well, both planets are still in their orbit, so you have to account for their motions. The Hohmann transfer is efficient for use of delta v but not the transfer time...what do you know, or what equations do you know, that can be used to account for the synodic period of the two planets?
Well I have used equations from the following webpage:
http://en.wikipedia.org/wiki/Hohmann_transfer_orbit
and then just added delta-v1 and delta-v2:
But apparently there's another way of doing it, which is escaping from Earth using equation:
V(excess velocity)² = v(initial velocity)² - v(escape velocity)²
When do I use which?
Thanks.
Thanks.
Just to clarify, the original question you asked was about the minimum wait time. Did you figure out what you needed to account for?
And for the
"V(excess velocity)² = v(initial velocity)² - v(escape velocity)²"
I'm assuming v(escapevelocity) is vfinal velocity, and V(excess velocity) is Vdelta. That's just the pythagorean theorem for the triangle formed with the three vectors...you still need to use the equations from the Hohmann transfer to calculate the actual values for the delta V required for each burn. So you need both, basically.
Let's put it this way. You are traveling from one object moving in a circle with one period to another moving in a different circle and at at different speed. The time it takes for you to move from one circle to the next is fixed. What conditions have to be met in order for the target object to be right point of its circle when you get there?
And for the
Oh right! So you use the equations for hohmann transfer to get the deltaV for the hyperbolic escape trajectory which takes it clear of the Earth's sphere of influence. And once you get deltaV1 for hohmann transfer and deltav1 for hyperbolic escape trajectory..you add both values to get the total deltaV for first stage?
