| Thread Closed |
Bug LaTex oddness |
Share Thread | Thread Tools |
| Jan3-09, 08:38 PM | #1 |
Mentor
LaTex oddness
If you check out this thread, you'll see some LaTeX strangeness.
Specifically, not all the images appear, and the ones that do appear seem not to match the LaTeX source. It's almost as if the images are offset: i.e. the n-th bit of source ends up displayed at the (n+3)-th slot. |
| Jan3-09, 10:02 PM | #2 |
Testing: [itex]\nu_\mu,~\nu_{\mu}[/itex]
[tex]\nu_\mu,~\nu_{\mu}[/tex] Seems to be okay here. Can't think of anything obvious that would do this just there. PS: You should try inline [itex]\LaTeX[/itex] for little bits in the middle of a sentence/paragraph. |
| Jan4-09, 07:53 AM | #3 |
Mentor
Vanadium,
You might try editing your entry that has the odd LaTex, and then SAVE it without actually changing anything. At least, that trick worked on a different bug that occurred in the PF Library ... see my comment of Jan1-09 here: http://www.physicsforums.com/library...item&itemid=25 |
| Jan4-09, 09:21 AM | #4 |
Mentor
LaTex oddness
Redbelly. I just did that. It looks the same, I'm afraid.
| Jan4-09, 10:29 AM | #5 |
Mentor
It's because some of your tags were [TEX] and some were [tex]. For some reason, the software doesn't like this. I've amended them, and now it looks OK to me.
| Jan4-09, 02:18 PM | #6 |
Mentor
Thanks, Cristo.
How odd that upper case works and lower case works, but you can't mix them. |
| Jan10-09, 06:51 AM | #7 |
I've seen that happen when editing LaTex. Clicking the refresh button clears it up. Now, does anyone know why it is necessary to "refresh" when you when you have just saved an edit?
| Jan10-09, 07:34 AM | #8 |
Now once the server has created the image, it replaces the latex source in your post with the URL of the latex image. When you click edit the server then replaced the latex image with the latex source so you can edit it. Now, when you edit a latex equation and click save, the server re-generates the latex image and overwrites the existing latex image file; so if I were to edit the equation corresponding to "2029042-0.png" then the new latex image also be called "2029042-0.png" and would replace the old file. Unfortunately, the way VBulletin is coded means that when you click save, only the text in your post is refreshed, meaning that you will be viewing cached images. This is good in one respect in that you don't have to waste bandwidth re-downloading images if you simply want to edit a post, however bad in another respect if you have edited a latex image. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: LaTex oddness
| Oddness in library | Forum Feedback & Announcements | 2 | ||
| Does anyone know the symbol for a vertical subset symbol Latex help | Math & Science Software | 7 | ||
| LaTeX help | General Math | 1 | ||
| about laTex | Math & Science Software | 5 | ||
| where I can download Latex | Math & Science Software | 4 | ||
