Thread Closed
Minimum Work needed?
Share Thread Thread Tools
Jan5-09, 05:38 PM   #1
what is the minimum wirk neede to push a 1000kg car 300m up a 17.5o incline?
Part a. Ignore friction
2. Relevant equations
So we are allowed to use the general equation
W=FdCos [tex]\theta[/tex]
3. The attempt at a solution
So I thought you would just do:
W= (1000)(9.8)(300)(cos17.5)
W=2803927Joules
However according to my teacher we should be getting
W= 8.8 x105 Joules
Does anyone know what I am doing wrong?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jan5-09, 05:42 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Draw a picture. Are you sure cos is the right trig function to be using? The force is aligned with the direction of the car's motion so W=F*d. How does the angle of the slope affect F? Split the force into components.
Jan5-09, 05:51 PM   #3
Oh, so you would have to use sin instead of cos. That makes more sense. I didnt know that you could interchange the trig function in the equation.
Thanks so much for your help!
Jan5-09, 05:55 PM   #4
Recognitions:
Quote by Littlemin5 View Post
You can't interchange the trig functions in the equation!! What happens when you are pushing the car up the incline is that the only force you have to overcome is the component of m*g that is tangent to the road. That's F_g=m*g*sin(incline angle). In the W=F*d*cos(theta) the theta is 0, since we are pushing in the same direction the car is moving. Those are two DIFFERENT angles. You aren't just substituting 'sin' for 'cos'. Try to be clear on this.
Jan5-09, 05:57 PM   #5
But I do have one more question if I was told that in the next part there was an effective coefficent of friction of .25 , wuld I just multiple my answer for Part 1 by .25?
Jan5-09, 06:01 PM   #6
Recognitions:
No. Not at all. Now you have to figure out the normal force before you can compute the frictional force. Can you do that?
Jan5-09, 06:07 PM   #7
Wouldn't you do 9800Cos17.5=9346.26N
so your answer there would be the Normal Force?
Jan5-09, 06:09 PM   #8
Recognitions:
Right. So now get the frictional force. The total force you have to push up the hill then the tangential force (as in the first problem) PLUS the frictional force.
Jan5-09, 06:12 PM   #9
so frictional force is 2336.565 and then I add that to 9800 which equals
12136.565.
From there I would do
(12136.565)(300)(sin17.5)
Right? And the answer I get would be my answer?
Jan5-09, 06:17 PM   #10
Recognitions:
No again. F_total=F_tangential+F_friction. Ok, F_friction is 2336N. The gravitational force component you are opposing is m*g*sin(17.5). Now take F_total*d
Jan5-09, 06:23 PM   #11
Wait I don't really understand the last comment you made. Could you please explain it in a bit more detail?
Jan5-09, 07:03 PM   #12
Here is another perspective. The displacement occurs at 17.5 degrees from the horizontal. The force, that is gravitational force, is acting down. We ignore the normal work because it has no component of force in the displacement (cos90=0). So, since mg is acting down, and the displacement is at 17.5 above horiztonal, we use the FDcosO. We know the force, mg; we know the displacement, 300m, and we know the angle between them, 17.5 + 90. So.. it should be 1000kg * 300m * 9.8 * cos (17.5 + 90). I think this is right. This is assuming no friction. Also, the work is negative but magnitude is positive.
Jan5-09, 09:32 PM   #13
Recognitions:
Quote by razored View Post
You could certainly do it that way. But it's pretty usual with inclined plane problems to split the m*g force into tangential and normal components. Going up the plane you only do work against the tangential component of m*g and the friction force. Add them and multiply by the distance.
Thread Closed
Thread Tools
Similar Threads for: Minimum Work needed?
Thread Forum Replies
How maximum and minimum thermometers work?? General Physics 2
Help Needed For Calculating The Minimum Introductory Physics Homework 3
My work: your thoughts needed! Introductory Physics Homework 5
Minimum Work for separation process Materials & Chemical Engineering 0
Focus in work...deeply needed help Academic Guidance 0
