Just these two problems I'll be done.
  • Thread starter Thread starter mustang
This discussion addresses two physics problems involving heat transfer and energy conservation. Problem 12 calculates the final temperature of a soup after adding a 0.012 kg cube of ice at 0.0 degrees Celsius, using specific heat and latent heat values for water. Problem 13 determines the temperature rise in four 3.8 kg steel brake disks after a 1610 kg automobile traveling at 28 m/s comes to a halt, applying the principles of kinetic energy conversion and the first law of thermodynamics. Both problems emphasize the importance of energy conservation in thermodynamic processes.
  • Understanding of specific heat capacity and latent heat of fusion
  • Familiarity with the first law of thermodynamics
  • Basic knowledge of kinetic energy and its conversion to internal energy
  • Ability to perform calculations involving heat transfer
  • Study heat transfer calculations in thermodynamic systems
  • Learn about the first law of thermodynamics and its applications
  • Explore specific heat capacity values for various materials
  • Investigate energy conservation principles in mechanical systems
Students studying physics, engineers involved in thermodynamics, and anyone interested in understanding energy conservation in mechanical systems.
mustang
Just these two problems ! I'll be done. :)
Problem 12.
Given: specific heat of water = 4186 J/kg degrees Ceicuis
and water's latent heat of fusion = 3.33 *10^5 J/kg.
A 0.012 kg cube of ice at 0.0degrees Ceicuis is added to
0.459 kg of soup at 80.4degrees Ceicuis.
Assuming that the soup has the same specific
heat capacity as water, find the final tem-
perature of the soup after the ice has melted.
Answer in units of degrees Ceicuis..
Problem 13.When a driver brakes an automobile, fric-
tion between the brake disks and the brake
pads converts part of the car's translational
kinetic energy to internal energy.
If a 1610 kg automobile traveling at 28 m/s
comes to a halt after its brakes are applied,
how much can the temperature rise in each
of the four 3.8 kg steel brake disks? Assume
the disks are made of iron (cp = 448 J/kg *
degrees C)
and that all of the kinetic energy is distributed
in equal parts to the internal energy of the
brakes. Answer in units of degrees C.
Note: I really am lost? Need step-by-step help!
a start: energy is conserved
Problem 12 assumptions:
- All energy is contained in the ice/soup system. In other words:
Qice = -Qsoup.
- Decide whether the final state is the state right at the melting of the last little bit of ice or the state at which the melted ice/soup system attains equilibrium.
- If you decide that the final state is the former, then assume that the melted ice does not take any energy from the soup. In other words, the melted ice stays at 0o C.
Then, you have either one or two (heat transfer0) processes to calculate.
Problem 13:
They give you the assumptions that you need to make. Use the first law of thermodynamics.
9K
15K
