No one has figured this out Problem I'm stuck
  • Thread starter Thread starter dken221
    Stuck
The discussion focuses on calculating the potential energy stored in a compressed spring that propels a 2.0 kg block vertically. The spring is compressed by 0.050 m, and when the block rises 0.60 m, it achieves a velocity of 1.7 m/s. Using the conservation of energy principle, the energy balance equation is established as E = 0.5mv² + 0.5kx², where the kinetic energy (KE) and potential energy (PE) are combined to determine the spring's potential energy.
  • Understanding of conservation of energy principles
  • Familiarity with potential energy (PE) and kinetic energy (KE) formulas
  • Knowledge of spring constant (k) and its significance in spring mechanics
  • Basic algebra for solving equations
  • Calculate the spring constant (k) using the potential energy formula PE = 0.5kx²
  • Explore the implications of energy conservation in mechanical systems
  • Investigate real-world applications of spring mechanics in engineering
  • Learn about energy transformations in vertical motion scenarios
Physics students, mechanical engineers, and anyone interested in understanding energy dynamics in spring systems.
dken221
a block of mass 2.0 kg is placed on a compressed vertical spring that is compressed .050m. (The spring and the block are not attached) The spring is released, and it propels the block vertically upward. when the block has risen .60m abovie its initial position, its velocity is 1.7 m/s. how much potential energy was originally in the spring?
Set up an energy balance equation. Then go from there.
First hint look into conservation of energy.
Here are some formulas to look into
PE=.5kx^2
k=spring constant
x=position
KE=.5mv^2
Combine them to form conservation of energy
E=.5mv^2+.5kx^2
