Spherical Polar Coords with Laplacian
The discussion revolves around the application of spherical polar coordinates and the Laplacian in the context of Legendre polynomials and Fourier series. Participants are exploring the derivation of coefficients in a potential function expansion and the integration techniques required for this problem.
  • Mixed
  • Participants discuss the use of Fourier series and Legendre polynomials, questioning the appropriateness of their methods and the definitions involved. There are inquiries about the integration limits and the role of orthogonality in extracting coefficients.
There is an ongoing exploration of the relationships between different mathematical concepts, with some participants clarifying their understanding of Legendre polynomials and integration techniques. Hints regarding the use of orthogonality properties have been provided, but no consensus has been reached on the correct approach.
Participants express uncertainty about the integration limits and the constants involved in their calculations, indicating potential gaps in their understanding of the problem setup and the mathematical tools required.
Firepanda
http://img243.imageshack.us/img243/1816/laplaceds2.jpg
Right I have a fair few questions on this, it's relating to question 7 only, although you need to refer back to the equation derived from question 6.
1) I used the equation from q6. as a Fourier series substituting r=a. I end up with an An of:
An = (Vo * a^n * Pn)/pi
For n = odd (i.e 2n+1)
And An = 0 for n = even.
Now looking at the result I should get (at the end of q7.) my a^n should in fact be a^-n, it stays as a constant during my integration so I can't change it there, so where do I change it?
2) My Fourier series was on the interal from 0 to pi/2, now from my definition of a Fourier series the integral should go from -L to L with 1/L constant before the integration. What is my 1/L here? I used 1/pi, not sure if this is correct.
3) For the second Fourier series in the integral of pi/2 to pi, I used 1/pi again for my 1/L (as defined before) but my An here doesn't get as far as being able to integrate it as I get 0 before I start, so I assume I leave this part out of the whole question?
Basically from my first integration I get close but I have no constants to my polynomials as I'm supposed to, which makes me think my question at 3) shouldn't be 0...
I see the orthoganality help at the bottom, how do I use this here?
ANY help is much appreciated!
Thankyou
1) I used the equation from q6. as a Fourier series substituting r=a...
Huh?! What function are you taking the Fourier series of and why?
This problem is about Legendre Polynomials not Fourier Series. Fourier Series are expansions of a function in terms of Cosines and Sines (or complex exponentials). Instead, the potential has been expanded
in terms of Legendre Polynomials:
[tex]V(r,\phi)=\sum_{n=0}^{\infty} A_n r^n P_n (\cos\phi)[/tex]
Your task here is to find the coefficients [itex]A_n[/itex] of this expansion using the orthogonality properties of Legendre Polynomials, not any Fourier series equations you might have.
Hint: what happens when you integrate [tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi[/tex] using first the Legendre expansion of your potential? And second, using your values of [itex]V(a,\phi)[/itex] given in Q7?
Ahh, ok thanks, sorry the question I did previously had a summation very simalar which I used Fourier for, and because it looked the same, and on the same question paper I thought I'd apply it here too.
I really haven't any experience with legendre polynomials, can i ask where the sin function came from in
[tex] \int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi[/tex]
please?
Also, how would I integrate this? The limits don't match any in the hints so I don't see how I can use them.
please?
Use the substitution [itex]x=\cos\phi[/itex]...what does that make [itex]dx[/itex]? How about the limits in terms of x?:wink: This is why I multiplied by [itex]P_m(\cos\phi)sin\phi d\phi[/itex] and integrated from zero to pi: it allows you to use the orthogonality conditon to extract your coefficients from the summation, allowing you to determine them.
Ah ok, so my 1st case would be integral from 0 to pi of
Pn(cosx)Pm(cosx)sinx dx ?
Where x = phi
This is where I don't see how to integrate it, do I hold things constant or?
Thanks btw
Where x = phi
No! Try again.:smile:
If [itex]x=cos\phi[/itex], then [itex]P_n(\cos\phi)=P_n(x)[/itex] and [itex]P_m(\cos\phi)=P_m(x)[/itex]. What is [itex]dx[/itex]? What is [itex]x[/itex] if [itex]\phi=0[/itex]? What is [itex]x[/itex] if [itex]\phi=\pi[/itex]?
x = 1 and x = -1
So my integral should be the other way around? from pi to 0?
Firepanda said:
x = 1 and x = -1
Yes. :smile:
Are you sure?:wink: What is [itex]dx[/itex] if [itex]x=\cos\phi[/itex]? (would calculating [itex]\frac{dx}{d\phi}[/itex] make more sense to you?)
gabbagabbahey said:
Yes. :smile:
sin(phi) d(phi) = dx...
lol, I'm sure you're trying to give me a subtle hint and I am just not picking up on it
Don't you mean [itex]-\sin\phi d\phi[/itex]? :wink:
That means that:
[tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi=\int_{1}^{-1}V(a,\phi)P_m(x)(-dx)=-\int_{1}^{-1}V(a,\phi)P_m(x)dx=\int_{-1}^{1}V(a,\phi)P_m(x)dx[/tex] and so your integral is in the correct form to use the hints.
That means that:
Ok sorry just got back from the gym or I would have replied sooner, i get this now thanks.
So I put the summation of V(a,phi) into this integral, where An and r^n are constants, so my integral is:
[tex] \int_{0}^{\pi}P_n(\cos\phi)P_m(\cos\phi)\sin\phi d\phi[/tex]
So i integrate this by parts?
Or perhaps I take
equal to 0?
So
[tex] V(a,\phi)(\sin\phi)=\sum_{n=0}^{\infty} A_n a^n P_n (\cos\phi) (\sin\phi) = P_n (\cos\phi)[/tex]
means
[tex]V(a,\phi)=\sum_{n=0}^{\infty} A_n = \sum_{n=0}^{\infty}(\sin\phi)/(a^n)[/tex]
Sorry lots of questions, I'm sure once I get my head around this I can do in the other integrals ranges.
There's no need to actually carry out the integration. That's the whole point of the hint.
[tex]\int_{0}^{\pi}P_n(\cos\phi)P_m(\cos\phi)\sin\phi d\phi=\int_{-1}^{1}P_n(x)P_m(x)dx[/tex]
with the substitution [itex]x=\cos\phi[/tex]<br /> <br /> P.S. I'm assuming you already rearranged the integral when you substituted the series expression for V by moving the integral inside the summation and treating [itex]A_n[/itex] as a constant?[/itex]
Firepanda said:
So
[tex] V(a,\phi)=\sum_{n=0}^{\infty} A_n a^n P_n (\cos\phi) = P_n (\cos\phi)(\sin\phi)[/tex]
means
No;
[tex]V(a,\phi)=\sum_{n=0}^{\infty} A_n a^n P_n (\cos\phi) \neq P_n (\cos\phi)(\sin\phi)[/tex]
Why would you think that the two expressions were equal?
[tex]V(a,\phi)=\sum_{n=0}^{\infty} A_n a^n P_n (\cos\phi)[/tex]
means that
[tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi=\int_{-1}^{1}V(a,\phi)P_m(x)dx=\int_{-1}^{1}\left( \sum_{n=0}^{\infty} A_n a^n P_n (\cos\phi)\right)P_m(x)dx[/tex]
[tex]=\int_{-1}^{1}\left( \sum_{n=0}^{\infty} A_n a^n P_n (x)\right)P_m(x)dx=\sum_{n=0}^{\infty} A_n a^n\left( \int_{-1}^{1} P_n (x)P_m(x)dx\right)[/tex]
Sorry ye I didn't mean those 2 were equal, I was in the middle of editing it but it wasn't saving it.
I was trying to use the sin somehow and end up with it in a taylor expansion, as the expansion has alternating signs just like the expression I'm trying to get to.
So I'm seeing now the summation has a zero in all the terms? And so for 0 < [tex]\phi[/tex] < pi, V(a, phi) = 0.
So now I just do the same for 0 < [tex]\phi[/tex] < pi/2 and pi/2 < [tex]\phi[/tex] < pi, and we'll see what happens?
Really? What about when m=n? Remember, you are summing over all values of n so there will be one value for which m=n is true.
Using the Legendre expansion of V you get:
[tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi=\sum_{n=0}^{\infty} A_n a^n\left( \int_{-1}^{1} P_n (x)P_m(x)dx\right)=?[/tex]
[tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi=\sum_{n=0}^{\infty} A_n a^n\left( \int_{-1}^{1} P_n (x)P_m(x)dx\right)=2/(2n+1)[/tex]
[tex]\sum_{n=0}^{\infty} A_n=\sum_{n=0}^{\infty}2/((a^n)(2n+1))[/tex]
[tex]\sum_{n=0}^{\infty} A_n=2/((a^n)(2n+1))[/tex]
Not quite;
[tex]\int_{-1}^{1} P_n (x)P_m(x)dx=\left\{ \begin{array}{lr} 0,& n\neq m \\ \frac{2}{2n+1}, & n=m \end{array}=\left\{ \begin{array}{lr} 0,& n\neq m \\ \frac{2}{2m+1}, & n=m \end{array}[/tex]
So,
[tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi=\sum_{n=0}^{\infty} A_n a^n\left( \int_{-1}^{1} P_n (x)P_m(x)dx\right)=\frac{2 A_m a^m}{2m+1}[/tex]
Since all of the terms in the sum are zero except fr the n=m term.
Now Q7 tells you that:
[tex]V(a,\phi)=\left\{ \begin{array}{lr} V_0,& 0< \phi < \pi/2 \\ 0, & \pi/2 <\phi <\pi \end{array}[/tex]
So you can also integrate [tex]\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi[/tex] using this expression and then compare your results.
Ok great, I was working through the Vo one and I've hit a brick wall, the derivation is pretty much the same all the way to
[tex]\int_{0}^{1}V_0 P_m(x)dx[/tex]
I can't see where to go from here, if I take Vo as V(a, phi) I can get to
[tex]\sum_{n=0}^{\infty} A_n a^n\left( \int_{0}^{1} P_n (x)P_m(x)dx\right)[/tex]
How do I get this into [tex]P_2n[/tex] or [tex]P_2n+1[/tex]?
[itex]V_0[/itex] is just a constant and can be pulled out of the integral:
[tex]\int_{0}^{1}V_0 P_m(x)dx=V_0\int_{0}^{1} P_m(x)dx[/tex]
Now, you know that:
[tex]\int_{0}^{1} P_{2n}(x)dx=0[/tex]
and
[tex]\int_{0}^{1} P_{2n+1}(x)dx=\frac{(-1)^n(2n)!}{2^{2n+1}n!(n+1)!}[/tex]
So, when m is even (i.e. when m=2n) you have:
[tex]V_0\int_{0}^{1} P_m(x)dx=0[/tex]
and when m is odd (i.e. when m=2n+1) you have:
[tex]V_0\int_{0}^{1} P_m(x)dx=\frac{(-1)^n(2n)!V_0}{2^{2n+1}n!(n+1)!}[/tex]
Which tells you that :
[tex]\frac{2 A_m a^m}{2m+1}=\int_{0}^{\pi}V(a,\phi)P_m(\cos\phi)\sin\phi d\phi=\left\{ \begin{array}{lr} 0, & m=2n \\ \frac{(-1)^n(2n)!V_0}{2^{2n+1}n!(n+1)!}, & m=2n+1\end{array}[/tex]
so [itex]A_m=?[/itex]
Greats thanks I <3 you, I won't ask for any more help, if I can't get the answer from that I'll prob just quit life altogether, great explanation!
  • · Replies 16 ·
  • · Replies 19 ·
