Solving Isosceles Triangle ABC: Finding Angle CDE
  • Context: Undergrad
  • Thread starter Thread starter Ursole
    Angle Triangle
The discussion revolves around solving for angle CDE in an isosceles triangle ABC, where specific angles and relationships are provided. Participants explore various methods, including trigonometric approaches and geometric constructions, to find the solution.
  • Some participants suggest that angle CDE could be 70 degrees, while others express uncertainty about this conclusion.
  • One participant describes a complex equation derived from the sine law but struggles to solve it without a graphing calculator.
  • Another participant mentions the existence of multiple elegant constructive proofs beyond the trigonometric solution.
  • Several participants propose that angle CDE could be 30 degrees, with one providing a detailed reasoning process involving various angles and relationships within the triangle.
  • There is mention of a hypothesis involving extending line BC and forming another isosceles triangle, which could lead to further insights about angle CDE.
  • Some participants express frustration with the problem, describing it as "evil" and challenging to solve.
  • References to external resources are made, suggesting that there are multiple ways to approach the problem.
Participants do not reach a consensus on the value of angle CDE, with multiple competing views and proposed solutions remaining unresolved.
Participants express uncertainty about the correctness of their calculations and the assumptions underlying their arguments. The discussion includes various angles and relationships that may not be fully resolved or simplified.
Readers interested in geometric problem-solving, trigonometry, and mathematical reasoning may find the discussion valuable.
Ursole
An isosceles triangle ABC has a point D on AB and a point E on AC.
Given:
Angle BAC = 20 degrees
Angle EBC = 50 degrees
Angle DCB = 60 degrees.
AB = AC
Find angle CDE.
Mathematics news on Phys.org
you could do this by scale drawing, but i can't be bothered to. I drew out some rough shetches and got a few angles but not the one you wanted.
I'd say its 70 degrees
This problem is evil.
Please tell me that the answer is at least a multiple of 10 degrees. Using sine law and some of the symmetry in the figure, I got it down to (sin x)/(sin x+20) = (sin 80)/(sin 40) or something like that, but I don't know how to solve such a complex equation without using a graphing calculator.
Davilla, your equation is correct.
Besides the trignometrical solution, there are as many as eight more elegant consructive proofs.
And, if one is really a masochist, it is possible to attempt a general solution in terms of the three given angles.
I think not...
For 0<x<90, sin(x+20) > sin(x). So this can't give you a solution in 0<x<90. And clearly (a reasonable drawing will show) x is in this range. So, it's probably the "something like that" that's right.
For all my talking, I'd better at least, start showing some results...
Since you suggest "constructive proofs" I think you could start by finding some point P1 on one of AB or AC such that triangle BCP1 is isosceles. On top of this construct more such isosceles triangles. If you're lucky, I think D or E will coincide with some Pn, from which you can calculate angles geometrically.
I "think" this may true. I tried it and found it to be true...but when I rechecked I found it was not...I'm not going to check again now...perhaps later.
Sorry, I meant 'something like that' is correct. :wink:
I said "something like that" because I was writing from memory. Anyways I labeled a different angle as x.
If that's true then I'm convinced there is a right angle in the figure, resulting in even more symmetry. Working backwards from my presumption there are at least seven formulas that, if could be derived from the statements in the problem, would prove that solution. The simplest is to show that 2 * DE = BE. But putting trig aside, the miraculous hidden line, if it exists, is elusive!
Perhaps I'm looking for something that's too easy. After all there are three or four statements needed to define the problem. If no two of them combine in a simplified form, then we're basically dealing with a system of several equations. Either I'm too lazy to churn them or this problem has exposed the limits of my atrophied cognitive capacity!
davilla said:
Working backwards from my presumption there are at least seven formulas that...
No, I meant that there are eight different ways to arrive at the correct answer without using trig. formulae.
Thirty degrees. Sneaky!
You have posted an answer, whereas I was hoping for a solution. :smile:
Call the bottom of the main triangle side A and the line running from the bottom left corner to theta side B.
Then, by the sin law on the bottom-right triangle,
A/sin40 = B/sin80
A/B = sin40/sin80
Now, notice that the bottom-left triangle is icosceles (80-50-50), so
A/sin(theta) = B/sin(160-theta)
A/B = sin(theta)/sin(160-theta)
Nw we can combine these to get sin(theta)/sin(160-theta) = sin(40)/sin(80)
theta=30.
Oh!
The answer is straight forward, I'll get it to you this time tomorrow.
Pfft
Given:
/_BAC=20 degrees
/_EBC=50 degrees
/_DCB=60 degrees
AB=AC
Find angle CDE
By definition ABC =ACB so ABC and ACB each equal 80 degrees.
ACB-CBE=DBE=30 degrees
By the same logic ACB-BCD=DCE=20 degrees
180-CBE-BCD-DCE=BEC=50 degrees
Note that lines DC and BE form a cross inside of the ABC triangle. We will call that cross point X.
180-BCE-BCD=70=BXC and therefore CXE is also equal to 70 degrees.
Hypothesis: If line BC is extended from C by a distance equal to CD and that distant point were called Y, and a second line is drawn from E to Y and called EY, then a triangle CDY will be formed which may be another isosceles triangle. If is true, then angle ACY=120 degrees and so is CDE+CYE=60. CDE would then equal 30 degrees.
Proof: If CDY were indeed an isosceles triangle, then line segment EY would be a straight line continuation of line DE. Since angle EXD=70 degrees and we wish to prove that CDE=30 degrees, it must be that DEX=80 degrees.
180-BEC-DEX=50=CEY. and CDY+ECY+EYC=180 removing any doubt that the assumption that CDY is an isosceles triangle.
Therefore it must be true that CDE=30 degrees.
Check out http://mathcircle.berkeley.edu/BMC4/Handouts/geoprob.pdf for some interesting historical background to the puzzle, plus EIGHT different solutions.
