Spring Energy-a block slides down a frictionless incline plane
The discussion centers on a physics problem involving a block of mass 13 kg sliding down a frictionless incline at an angle of 30°, compressing a spring with a spring constant of 27,000 N/m. The block momentarily stops after compressing the spring by 5.8 cm. The calculated speed of the block when it first touches the spring is 2.53 m/s, but this result is questioned due to the relevance of gravitational potential energy in the context of the problem. Participants suggest focusing on the kinetic energy of the block and the potential energy of the spring at maximum compression to accurately determine the block's velocity.
  • Understanding of gravitational potential energy (Ug = mgh)
  • Knowledge of spring potential energy (Us = 1/2kx²)
  • Familiarity with kinetic energy equations (K = 1/2mv²)
  • Basic principles of energy conservation in mechanics
  • Review energy conservation principles in mechanical systems
  • Learn how to derive spring constants from force and displacement
  • Explore the application of 30-60-90 triangles in physics problems
  • Investigate the effects of incline angles on kinetic and potential energy
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy conservation in systems involving springs and inclined planes.
lu6cifer
Spring Energy--a block slides down a frictionless incline plane
A block of mass m = 13 kg is released from rest on a frictionless incline angled of angle θ = 30°. Below the block is a spring that can be compressed 2.0 cm by a force of 270 N. The block momentarily stops when it compresses the spring by 5.8 cm.
What is the speed of the block when if first touches the spring?
Ug = mgh, Us = 1/2kx2, K = 1/2mv2
By K = 1/2kx^2, I know the spring constant. 270 N * 0.02m = 1/2k(0.02)2. So, k = 27,000. I solved for the h in mgh--> 1/2kx^2 = mgh, 1/2(27,000)(0.058)^2 = 13 * 9.81 * h. h = 0.356 m. The equation when it first touches the spring is 1/2mv^2 = mgh. To find this new h value, I used the 30-60-90 triangle. When h was 0.356 m, the length of the relative incline is 2 * 0.356, or 0.712. So, the length of the new incline is 0.712 - the length of compression. So, 0.712 m - 0.058 m = 0.654 m, which is the length of the incline. Using 30-60-90 triangles, the relative vertical height of the incline is 0.654/2 = 0.327 m.
So, if mass cancels, 1/2(v^2) = 9.81 * 0.327. v = 2.53 m/s
But my online homework thing says it's wrong??
If I read the question correctly, the spring is oriented along the incline. If this is the case, think about what the final length of the spring will be when the system is at equilibrium.
Also, I'm not sure that the equation Ug = mgh is necessarily relevant here, as the height from which the block is released is not part of the question. If you look at the kinetic energy of the block when it first contacts the spring and the potential energy of the spring when it is compressed to its maximum amount, you should have all the information needed to determine the velocity of the block.
  • · Replies 27 ·
11K
  • · Replies 18 ·
  • · Replies 33 ·
