Potential Energy and Conservation of Energy Problems
The discussion revolves around problems related to Potential Energy and Conservation of Energy, specifically in the context of mechanics. Participants are examining scenarios involving a block sliding on a frictionless surface and the interaction with springs, as well as the energy transformations involved when a person jumps into a net.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to apply energy conservation principles to various problems, questioning their setups and calculations. There is discussion about the correct application of formulas for kinetic and potential energy, as well as the conditions under which these energies are equal.
Some participants have identified errors in their initial approaches and are seeking clarification on the correct relationships between kinetic and potential energy. There is ongoing exploration of the conditions under which energy is transferred between the block and the spring, with some guidance being offered regarding the setup of equations.
Participants are working under the constraints of homework problems, which may limit the information available for solving the problems. There is also a focus on understanding the implications of energy conservation in different scenarios presented in the questions.
Matthew.C21
Hi everybody! So this is my first time using this forum. I'm currently taking AP Physics C: Mechanics in high school and I have some questions concerning Potential Energy and Conservation of Energy. Thanks for taking the time to help me!
32. A 4.0-lb block slides along a horizontal frictionless surface at 8 ft/s. It is brought to rest by compressing a very long spring of spring constant (1/8) lb/ft. The maximum spring compressing is:
A. 4 ft
B. 8 ft (Correct Answer)
C. 16 ft
D. 2 ft
E. 45 ft
33. A block of mass m is initially moving to the right on a horizontal frictionless surface at a speed v. It then compresses a spring of spring constant k. At the instant when the kinetic energy of the block is equal to the potential energy of the spring, the spring is compressed a distance of:
A. v sqrt(m/2k) (Correct Answer)
B. (1/2)mv^2
C. (1/4)mv^2
D. mv^2/4k
E. (1/4)sqrt(mv/k)
34. A 200-lb man jumps out of a window into a fire net 30 ft below. The net stretches 6 ft before bringing the man to rest and tossing him back into the air. The maximum potential energy in (ft*lb) of the net is:
A. 7200 (Correct Answer)
B. 6000
C. 1800
D. 1200
E. 600
Emech = K + U
U = 1/2k(x)^2
U = mgh
K = 1/2m(v)^2
32. 1/2 (1/8) x^2 = 1/4 (4) 8^2 <<<< Doesn't work, don't know how I should be setting up the equation.
33. 1/2 kx^2 = 1/2 mv^2
kx^2 = mv^2
x^2 = mv^2/k
x = v sqrt(m/k) <<<< Why am I missing the 2k?
34. mgh = 1/2kx^2
200*32*3 = 1/2*k*6^2
192000 = 18k
k = 10,666.67
U = 1/2 (10,666.67) 6^2 <<<< WAYYYY off.
Welcome to PF.
What are you stuck on?
After looking over the problem, I realized that i forgot to divide the lb by gravity. That takes care of 32 and 34. For 33, I don't really understand why the answer is vsqrt(m/2k) instead of vsqrt(m/k)
Your energy equation is incorrect. If the initial velocity of the block is v, when the block hits the spring, it will lose kinetic energy which will be converted to potential energy. When the potential energy of the spring is equal to the kinetic energy of the block, let the velocity of the block be v1.
The potential energy gained by the spring is equal to the difference in kinetic energy of the block (initial-current). The current kinetic energy of the block is equal to the potential energy which gives you your answer. Try to set it up.
so Usp = Etotal - Ek?
The point to realize is that your use of the equation, "1/2 kx^2 = 1/2 mv^2" transfers all energy from the block, to the spring; but, the problem statement requests that you determine the position where Kblock = Uspring. Because Uspring started at zero, the point where the magnitudes are equivalent is 1/2Kblock initial, i.e. the block transfers half of its energy to the spring.
