How Do You Solve a Non-Square Linear Transformation Equation?
The discussion focuses on solving a non-square linear transformation equation represented by the matrix A = [[1, -1], [2, 5], [3, 4]]. The transformation T_A maps a 2x1 vector x in R² to a 3x1 vector Ax in R³. The goal is to find a vector x such that T_A(x) = [7, 0, 7]. Since A is not invertible, the solution involves expressing the equations directly rather than relying on matrix inversion. The final solution is x = [5, -2], verified by substituting back into the original equations.
  • Understanding of linear transformations and matrix representations
  • Familiarity with solving systems of linear equations
  • Knowledge of row reduction techniques for matrices
  • Basic concepts of vector spaces and dimensions
  • Study the method of row reduction for solving linear systems
  • Learn about the implications of non-square matrices in linear algebra
  • Explore the concept of vector spaces and their dimensions
  • Investigate alternative methods for solving linear equations, such as least squares
Students and professionals in mathematics, particularly those studying linear algebra, as well as engineers and data scientists dealing with linear transformations and systems of equations.
roam
[tex]A = \left[\begin{array}{ccccc} 1 & -1 \\ 2 & 5 \\ 3 & 4 \end{array}\right][/tex]
Let [tex]T_{A}: R^2 \rightarrow R^3[/tex] be the matrix transformation that maps a [tex]2 \times 1[/tex] column vector x in R2 into the [tex]3 \times 1[/tex] column vector Ax in R3.
The relationship can be expressed as TA(x) = Ax
Find a vector x in R2 whose image under TA is [tex]\left(\begin{array}{ccc}7\\0\\7\end{ar ray}\right)[/tex]
3. The Attempt at a Solution
If we write this in component form as:
[tex]\left[\begin{array}{ccccc} 1 & -1 \\ 2 & 5 \\ 3 & 4 \end{array}\right][/tex] [tex]\left[\begin{array}{ccccc} x_{1} \\ x_{2} \end{array}\right][/tex] [tex]=\left[\begin{array}{ccccc} 7 \\ 0 \\ 7 \end{array}\right][/tex]
I could solve for [tex]\left[\begin{array}{ccccc} x_{1} \\ x_{2} \end{array}\right][/tex]
However a linear equation in the matrix form "AX = B" can be solved easily for X if "A" is invertible and its inverse is known, you get: X = A-1B
But [tex]A = \left[\begin{array}{ccccc} 1 & -1 \\ 2 & 5 \\ 3 & 4 \end{array}\right][/tex] is NOT square and therefore it has no inverse!
Does anyone know how to find the solution?
Thank you
Thank you
n equations in m unknowns with n> m MAY not have a solution at all since a linear transformation from an m dimensional vector space to another vector space maps it into an at most m dimensional subset of the second vector space. That's why there is no inverse matrix. There will be a solution only if the given vector, here <7 0 7> happens to lie in that subspace. In any case, finding an inverse matrix is seldom the best method of solving a matrix equation anyway.
I think the simplest thing to do for as simple a system as this is just write out the equations themselve rather that use matrices:
[itex]x_1- x_2= 7[/itex], [itex]2x_1+ 5x_2= 0[/itex], and [itex]3x_2+ 4x_2= 7[/itex]
The first equation says that [itex]x_1=7+ x_2[/itex]. Putting that into the second equation [itex]2(7+ x_2)+ 5x_2= 14+ 7x_2= 0[/itex] so [itex]x_2= -2[/itex] and then [itex]x_1= 7- 2= 5[/itex]. Now check to see whether they satisfy the third equation: [itex]3x_1+ 4x_2= 3(5)+ 4(-2)= 15- 8= 7[/itex].
If you must use matrices, write the augmented matrix:
[tex]\begin{bmatrix} 1 & -1 \\ 2 & 5 \\ 3 & 4\end{bmatrix}\begin{bmatrix} 7 \\ 0 \\ 7\end{bmatrix}[/tex]
and row reduce. Subtract 2 times the first row from the second and 3 times the first row from the third to get
[tex]\begin{bmatrix} 1 & -1 \\ 0 & 7 \\ 0 & 7\end{bmatrix}\begin{bmatrix} 7 \\ -14 \\ -14\end{bmatrix}[/tex]
Now divide the second row by 1, add the second row to the first row and subtract the second row from the third row to get
[tex]\begin{bmatrix} 1 & 0 \\ 0 & 1 \\ 0 & 0\end{bmatrix}\begin{bmatrix} 5 \\ -2 \\ 0\end{bmatrix}[/tex]
The fact that the third row is now completely zeros tells us that is a correct solution.
