Resonace Frequency of Bodies/Materials
  • Context: Graduate
  • Thread starter Thread starter jze
    Frequency
The discussion centers on calculating the mechanical resonance frequencies of materials, specifically glued wood, shaped into an inverted funnel or bell form. Participants explore the relationship between the size and shape of the form and its mechanical resonance frequencies, as well as the factors involved in determining these frequencies.
  • Experimental/applied
  • One participant, Dennis, seeks methods to calculate the mechanical resonance frequencies of glued wood and is interested in how the size and shape of the form affect these frequencies.
  • Dennis expresses a desire for a formula to predict outcomes before engaging in physical experimentation, mentioning a tuning fork's role in creating harmonic resonance.
  • Another participant suggests that Dennis's choice of complex shapes and materials may complicate both theoretical and experimental aspects of the investigation and recommends considering simpler alternatives.
  • A participant shares links to resources that may provide relevant information for Dennis's inquiry.
  • Dennis acknowledges the shared links and indicates a willingness to continue experimenting and sharing findings.
There is no clear consensus among participants. While some suggest simpler approaches, others support Dennis's exploration of more complex shapes and materials. The discussion remains open-ended with varying perspectives on the challenges involved.
Participants have not fully defined the assumptions or parameters for calculating resonance frequencies, and the discussion reflects uncertainty regarding the complexity of the chosen shapes and materials.
jze
Hi there,
I'm would like to know how to calculate mechanical resonance frequencies of material and form. ie. the materials I'm choosing first are glued wood, as they are much easier to cut/shape. The form would be shaped into an inverted funnel like or bell shaped of different sizes and hollow on the inside. The ideal thickness would be around 1 to 2 cm.
Firstly how do i go about calculating mechanical resonance frequency of wood and most importantly how does the size and shape of the form effects the mechanical resonance frequencies? How do I determine the factors involved?
Briefly- I would like to have a tuning fork, being place on the form to create harmonic resonance frequency, not only a louder sound, but also the right frequencies that will vibrate the body, hopfully to create harmonics.
naturally i can do a trail and error method, but as this work is rather strenuous, i would like some form of formula to determine what will happen before i start the particle work.
any form of help would be greatly appreicated.
best
Dennis
Dennis I don't know what level you are at but you seem to have chosen very difficult shapes and material to investigate the difficulties being both theoretical and experimental.May I suggest that you go for something simpler.
hi there,
thanks for the link <atyy>. this is almost something I'm looking for.
yes <DadFace> you might be right, this will take some time and experimentation to build.
I will write with more about my findings and questions.
thanks
  • · Replies 17 ·
