Is Earth's gravitational pull equal to an object's falling force?
The discussion revolves around the nature of gravitational forces, specifically whether the gravitational pull of the Earth is equal to the force an object exerts while falling. It explores concepts from Newton's laws, gravitational interactions, and the implications of mass in gravitational acceleration.
  • Some participants assert that the force an object exerts while falling is equal and opposite to the gravitational pull of the Earth, as per Newton's third law.
  • One participant emphasizes that while the force exerted by a falling object on the Earth is equal, the Earth's massive size means this force does not result in noticeable movement.
  • A question is raised about the mechanism of force emission, with one participant suggesting that gravitons might be involved in this interaction.
  • Another participant draws a parallel between gravitational interactions and electromagnetic interactions, mentioning the roles of photons in charge interactions.
  • There is a discussion on Newton's law of gravitation, with a participant noting that gravitational attraction occurs due to mutual mass, regardless of the specific mechanism (gravitons, gravity waves, etc.).
  • One participant expresses disagreement with the statement that "gravitational acceleration is independent of mass," suggesting that this is a misinterpretation in introductory physics contexts.
  • Another participant clarifies that in many practical scenarios, the mass of the falling object is negligible compared to the Earth's mass, allowing for simplifications in calculations of gravitational acceleration.
  • A formula for calculating gravitational acceleration is presented, highlighting the mass of the Earth as a key factor.
Participants express differing views on the interpretation of gravitational acceleration and the implications of mass in gravitational interactions. There is no consensus on the correctness of certain statements regarding gravitational acceleration and the mechanisms of gravitational force.
Some discussions involve assumptions about the context in which gravitational acceleration is considered, particularly in introductory physics settings where the mass of objects is often treated as negligible compared to that of the Earth.
fbsthreads
if an object is falling to earth, is the equal and opposite force to gravity (Newtons 3rd law) the pull of the Earth towards the object?
Absolutely. If the Earth pulls on you with a force of 700 N, then you pull right back on the Earth with 700 N as well. It's just not so apparent because the Earth is so massive that the extra 700 N doesn't move the Earth much at all.
but to emit 700N wouldn't i have to do this by emitting gravitons?
Yes. It is a similar situation to that you have when two charges are interacting. Both emit and absorb photons, and their momenta are affected accordingly.
Newton's law of gravitation is given as
[tex]F = G\frac{m_1m_2}{r^2}[/tex]
where F is the gravitational force between two bodies, G is the universal gravitational constant, m1 and m2 are the masses of the two bodies being considered, and r is the distance between the centers of mass of the two bodies.
However this gravitational force is manifest, by gravitons or gravity waves or space-time curvature or whatever (I am not knowledgeable about such things), you attract the Earth and the Earth attracts you by virtue of your mutual mass. The mechanism for your attracting the Earth is the same by which you are attracted to it.
This is true for all mass in the universe: Every object with mass is attracted to every other mass. Your pencil is attracted to your calculator. Your TV is attracted to your remote. Your cat is attracted to your refrigerator. It doesn't matter what the object is: if it has mass, it produces a gravitational field that influences other masses.
We don't see all of these small gravity forces between objects because gravity is such a very WEAK force. It takes an object as massive as a planet for us to notice its gravity.
This is why I never liked and still do not like when my physics teacher says that "gravitational acceleration is independent of mass"...It just bugs me.
well yes, saying "gravitational acceleration is independent of mass" is of course an incorrect statement, but it's because your teacher is using it to loosely. In an intro to physics setting unless you are talking about the motion of planets you almost always talk of g as being = 9.8 m/s^2 because the mass of whatever you are talking about is usually a lot smaller then the mass of the earth. In this case the mass of whatever you are analyzing becomes negligible and you do not have to worry about it.
The value of Earth's gravitational acceleration can be found from Newton's law of gravitation by simply leaving out the small mass from the equation:
[tex]g=G\frac{M}{r^2}[/tex]
Here M is the mass of the Earth.
  • · Replies 49 ·
  • · Replies 51 ·
  • · Replies 20 ·
  • · Replies 19 ·
