How would you go about describing a precise position?
  • Thread starter Thread starter OAQfirst
    Position
The discussion revolves around the challenge of describing a precise position on a surface, specifically at an atomic level, such as on the tip of a fingernail. Participants explore the necessary frameworks and measurements required to express such positions accurately, touching on concepts of coordinate systems and degrees of freedom.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that to express a position to within an atom, a set of axes and a zero position must be established, requiring six fixed values.
  • Another participant proposes that measuring the position of an individual atom could be done using an Atomic Force Microscope (AFM), although removal of the atom might be necessary.
  • A question is raised about the necessity of six fixed values, with a participant arguing that four points could suffice for defining a position.
  • Clarification is provided that the six values correspond to the x, y, z coordinates of the origin and the roll, pitch, and yaw angles for the axes.
  • One participant expresses confusion about using only two points to define three axes, arguing that more points are needed to avoid ambiguity in the coordinates.
  • A participant mentions considering a six-axis coordinate system for a project and seeks examples and appropriate search strategies for further information, specifically regarding units of measurement for short distances between atoms.
Participants exhibit disagreement regarding the number of points required to define a coordinate system adequately, with some asserting that six values are necessary while others argue for fewer points. The discussion remains unresolved on this aspect.
Participants' claims depend on assumptions about the definitions of coordinate systems and the context of measurement, which are not fully articulated. There are also unresolved questions regarding the practical application of these concepts in measuring atomic positions.
This discussion may be of interest to those exploring atomic-scale measurements, coordinate systems in physics, or applications in fields such as nanotechnology and materials science.
OAQfirst
Say you have a point on a surface, such as somewhere on the tip of your fingernail, and you needed to express that position to within an atom. How would you do it? I was wondering if anyone even does this sort of thing.
I understand that some position would need to be chosen relative to the point, but beyond that I'm stumped.
You need to choose a set of axis and some way to fix them and a zero position to measure from. In all you need 6 fixed values.
You could measure the position of an individual atom on a finger tip with an AFM (but you might need to remove it first)
Can you elaborate what you mean by "6 fixed values"? Especially why 6, as 4 points seems to be enough. Could be I am missing something.
An x,y,z of the origin and roll,pitch,yaw angles for the axis.
Alternatively two xyz points.
To lock down 6 degrees of freedom you need 6 values.
I don't get it :sad:
I can't see how can I use just two points to define three axes. One axis OK, but nothing more, coordinates of every point that doesn't lie on the axis are ambiguous (at best, giving distance from both points, I can show circle on which the point lies). Three points - and I can have two axes (or I can give correct coordinates of every point on the plane, that's assuming my three points are not colinear). Finally, four points can define three axes, and that will allow me to give coordinates of every point in 3D.
I've been thinking this over and I believe a six axis coordinate would work for my project (book). I searched Google, but all I find are links for that PS3 controller.
I would really like to see an example of what that would look like on paper. What search strategy should I be using? And what unit of measurement is used for very short distances between atoms?
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 19 ·
