Nonuniform circular motion due to gravity.
The discussion centers on the analysis of a ball's motion as it rolls off a cylindrical incline under the influence of gravity. The author derived the tangential acceleration formula, dv/dt = gsinθ, and explored the complexities of integrating the resulting equations. The solution to the integral involves the elliptic integral of the first kind, represented as t = (2a√((b - cos x)/(b-1)) * F(x/2, -2/(b-1))) / √(b - cos x) + C. This integral cannot be solved using elementary functions, highlighting the advanced nature of the problem.
  • Understanding of nonuniform circular motion and gravitational effects
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of elliptic integrals, specifically the elliptic integral of the first kind
  • Basic physics concepts related to motion on inclined planes
  • Study the properties and applications of elliptic integrals, focusing on the first kind
  • Learn advanced integration techniques, particularly for non-elementary functions
  • Explore the dynamics of rolling motion and its equations of motion
  • Investigate the relationship between angular displacement and linear motion on circular paths
Students of physics, mathematicians dealing with advanced calculus, and engineers interested in dynamics and motion analysis will benefit from this discussion.
3dot
The question I encountered asked at what angle would a ball rolling off a cylindrical incline leave the surface of the incline. This problem i solved. But it got me thinking, how would I describe the motion of that ball in terms of time?
To generalize the problem I started like this. A ball starts rolling from some point on a circular incline with some initial speed.
We draw 2 lines. A line through a point on the circular incline and the circle's center. And a vertical line through the center (parallel to the direction of gravity). Let the angle between these lines be θ. Then the tangential acceleration, which changes speed is:
dv/dt=gsinθ
(dv/ds)(ds/dt)=gsinθ (s being the distance traveled,R-radius, s=Rθ, ds=Rdθ)
vdv=gRsinθdθ
v2-v02=2gR(cosθ0-cosθ)
ds/dt=±√(2gR)×√(cosθ0+v02/(2gR)-cosθ)
Here you dt=[tex]\frac{a}{\sqrt{b-cos\theta}}[/tex]dθ where both a and b are constants, integrating this is where I get stuck. replacing tan(theta/2)=x and using the identity cos theta = 1-tan^2(x/2)/sec^2(x/2) does seem to help until you need to integrate 1 over square root of a quartic.
Can someone offer help with this integral?
Hello 3dot, and welcome to Physicsforums!
Unfortunately, the solution to that integral is somewhat complicated and can not be solved in terms of elementary functions. The solution, if you want it, is
[tex]t = \frac{2a\sqrt{\frac{b - \cos x}{b-1}} \cdot F\left[\frac{x}{2}, \frac{-2}{(b-1)}\right]}{ \sqrt{b - \cos x}} + C[/tex]
where F(x|m) is the elliptic integral of the first kind, and C is an arbitrary constant.
You can find some information of That Elliptic Integral here:
http://mathworld.wolfram.com/EllipticIntegraloftheFirstKind.html
Hopefully that helps.
Thanks, I now know what I should read about.
