Thread Closed
Čerenkov radiation: Why is it possible?
Share Thread Thread Tools
Jan11-09, 12:03 AM   #1
Well, I was reading about neutrino the other day, and I came across the Čerenkov radiation. I understand that the universal speed limit is the speed of light, c, in a vacuum. I understand that Čerenkov radiation occurs when objects (not as physical object, but stuff) travel faster than light in an alternate medium. What I don't understand is:
How is it that a medium exists that can slow down light more than some other substance? For example, air: it slows down a person and the bike the person is riding at the same time. How is it that this substance exists that can slow down one thing (ie light) more than other things (also in the same medium)?
Also, is there special characteristic of these substances?
(Note: I am still a high school senior taking basic differential equations at school, please refrain from writing fancy 2 page long equations/formulas. Thanks!)
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan11-09, 12:11 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Hunterbender View Post
What happens is that in many media, the electromagnetic wave which is light sets into oscillation charges (the electron clouds of the composing atoms and so). These oscillating charges on their turn send out electromagnetic radiation which is perfectly coherent with the incident radiation, but which has a phase shift. The combination (interference) of the incoming radiation and this emitted radiation make that there is an overall shifting of the phase in the material which is proportional to the amount of material traversed: that's nothing else but an effective slowing-down of the original wave. So you can consider this as two different situations:
You can consider that light always travels at c (as in a vacuum), but take into account all these secondary sources (which also send out light at c).
Or, you can only consider the the initial light, without the extra sources, but with a modified velocity. The modified velocity is a "trick" which allows you to take effectively into account all the wave-atom interactions.
Now, if a wavesource travels faster than the effective wave it emits, you get constructive interference of all wavefronts on a conical surface. With sound, that's the sonic boom, and with light, that's Cherenkov radiation.
Jan11-09, 01:04 AM   #3
First of all, thank you so much for responding.
I am wondering if I am understanding this correctly. So there are two different measurement of "speed" (or velocity I guess). One of which measure the velocity of its oscillating charges (which has some phase). The other is the velocity of the wave (of the light).
In a medium, the phase of the oscillating charge changes more than the velocity of the wave, so it "break" through in a phenomenon we call Cerenkov Radiation. Is that correct?
Then, (sorry a few more questions pop up, if you don't mind) does all medium demonstrate such an effect (separating the wave into oscillating charges and wave itself)?
Thank you for your time.
Ben Zheng
Thread Closed
Tags
Čerenkov radiation, cerenkov, nuetrino, relativity, speed of light
Thread Tools
Similar Threads for: Čerenkov radiation: Why is it possible?
Thread Forum Replies
Wave questions and Čerenkov radiation General Physics 5
Čerenkov radiation Special & General Relativity 10
UV Radiation Introductory Physics Homework 5
radiation Introductory Physics Homework 3
EM radiation and Nuclear Radiation Classical Physics 6
