Bouyant force and apparent weight
The discussion centers on calculating the percentage of a solid sphere immersed in water to achieve specific apparent weights, given the sphere's radius of 0.20 m, a density of 850 kg/m³, and two apparent weights of -149 N and -3.86 x 10^-4 N. The relevant equations include the buoyant force formula (Fb = roh x V x g) and the relationship between the volume immersed and the total volume (% immersed = V immersed / V total = roh obj / roh fluid). The user seeks guidance on applying these principles to determine the required immersion percentages for the specified apparent weights.
  • Understanding of buoyant force and Archimedes' principle
  • Familiarity with the concepts of apparent weight and normal force
  • Knowledge of basic physics equations involving mass, volume, and density
  • Ability to manipulate algebraic equations to solve for unknowns
  • Calculate the volume of the sphere using the formula V = (4/3)πr³
  • Learn how to apply Archimedes' principle to determine the percentage of an object submerged in a fluid
  • Explore the relationship between density and buoyancy in different fluids
  • Investigate the effects of varying densities on apparent weight in fluid mechanics
Students studying physics, particularly those focusing on fluid mechanics and buoyancy, as well as educators seeking to clarify concepts related to apparent weight and buoyant forces.
chantalprince
This question is continued from a problem that I have already solved. This is what I know from the previous problem that will be helpful:
r= 0.20 m
roh of solid sphere= 850 kg/m^3
mass sphere= 3.94 x 10 ^-5 kg
I also have 2 apparent weights that I solved for when the tension in the system is
a. 150 N ----> Normal force (apparent weight) Fn = -1.49 x 10^2
b. 0 N -----> Fn = -3.86 x 10^-4 N
(Hopefully those are correct)
Now- the problem I came for help on:
A room is partially filled with water with a sphere in it and the sphere is on a scale. What percentage of the sphere must be immersed in the water in order to achieve the same apparent weights as above (a and b).
And- What percentage of the sphere must be immersed to achieve an apparent weight of zero?
% immersed = V immersed/ V total = roh obj/roh fluid
buoyant force (Fb) = roh x V x g
Fn = mg + ma (a = O)
And from a full body diagram I have this:
Fn + Fb - mg = ma (whch is zero)
Well...I really am not sure what to do. One fact that I know and I think will help me is that if an object is say 90% underwater, then the roh of the object is 90% of the fluid...
I need a kick in the right direction please.
Start with this, the 3 forces acting on the sphere. Fill in the detailed formula for each force.
Ok- here's what I got, but I am not sure what this implies...
mg + roh x V x g -mg = 0
mg cancels and I end up with roh x V x g = 0
  • · Replies 21 ·
