{ changing dxdx to dydx }, When ? and How ?
  • Context: Undergrad
  • Thread starter Thread starter AbuYusufEg
The discussion revolves around the conditions and methods for changing the order of integration in double integrals, specifically transitioning from dxdy to dydx. Participants explore the reasoning behind this change, including practical examples and theoretical implications.
  • Homework-related
  • One participant questions when and how to change the order of integration, noting that it may be beneficial when one variable is easier to integrate than the other.
  • Another participant mentions that in most practical cases, the order of integration can be interchanged, but issues arise with integrals that do not converge absolutely.
  • A participant requests clarification on an example from Wikipedia, indicating difficulty in understanding the implications of changing the order of integration.
  • A detailed example is provided, illustrating a specific integral where changing the order of integration leads to a different result due to the integrand's properties.
  • One participant suggests that visualizing the integration bounds can help in determining how to switch the order of integration.
Participants express differing levels of understanding regarding the conditions under which the order of integration can be changed. While some agree on the general principle of interchangeability, others highlight specific cases where this does not hold true, indicating a lack of consensus on the topic.
Participants reference the importance of absolute convergence and provide an example where the integrand's behavior affects the ability to change the order of integration. The discussion includes unresolved questions about specific cases and the implications of the examples provided.
Students preparing for exams in calculus or those interested in understanding the nuances of double integrals and the conditions for changing the order of integration.
AbuYusufEg
for integration in two variables, say x and y
let the original formula have dxdy
when can i change it into dydx? and how to do that ?
And also: Why ?
the only reason for doing that i know till now is for example i have a function that is easy-to-integrate w.r.t. y but not w.r.t x, so i do make dy before dx to integrate the function w.r.t y then x, instead if x then y
But how i do that ? and When ? And Why ( Another reasons .. ) ?
In most cases you encounter in practice you'll find that you can interchange the order of integration. The problem arises when the integral does not converge absolutely (that is, integrating the absolute value of the integrand yields an infinite result). See the following page for more information and an example of a function whose values differ by a sign under swapping the order:
http://en.wikipedia.org/wiki/Fubini's_theorem
Can you write some example please ? as i can't get it from the wikipedia's page !
i'm still needs help here!, I've exam after about 10 hours ..
What do you mean you "can't get it from wikipedia's page"? Do you mean the page isn't working or you don't understand the example? I'll assume the latter and explain wikipedia's example:
The example given is
[tex]\int_0^1\int_0^1 \frac{x^2-y^2}{(x^2+y^2)^2}\,dy\,dx[/tex]
which the page claims you cannot change the order of integration in order to perform the integral. You can see this directly by noting that if you relabel the variable x by y and the variable y by x, the integrand looks exactly the same except that the terms in the numerator are reversed and the dydx is now dxdy. Pulling a minus sign out of the numerator you see that the integrand is again the same as before except for changing the order of integration - hence by changing the order of integration the value you calculate will change by a minus sign (in THIS particular example - this does NOT mean that in general changing the order of integration for such functions will just change the result by a minus sign).
The reason you can't change the order without changing the value you calculate is that the function you are integrating is not absolutely convergent, meaning
[tex]\int_0^1\int_0^1<br /> \left|\frac{x^2-y^2}{(x^2+y^2)^2}\right|\,dy\,dx=\infty[/tex]
Observe the evaluation done on the page:
[tex]\int_0^1\int_0^1<br /> \left|\frac{x^2-y^2}{(x^2+y^2)^2}\right|\,dx\,dy=\int_0^1\left[\int_0^y<br /> \frac{y^2-x^2}{(x^2+y^2)^2}\,dx+\int_y^1\frac{x^2-y^2}{(x^2+y^2)^2}\,dx\right]\,dy[/tex]
[tex]=\int_0^1\left(\frac{1}{2y}+\frac{1}{2y}-\frac{1}{y^2+1}\right)\,dy=\int_0^1 \frac{1}{y}\,dy-\int_0^1\frac{1}{1+y^2}\,dy.[/tex]
To quote wikipedia,
When
[tex]\int_a^b\int_c^d \left|f(x,y)\right|\,dy\,dx=\infty[/tex]
then the two iterated integrals
[tex]\int_a^b\int_c^d f(x,y)\,dy\,dx\ \mbox{and}\ \int_c^d\int_a^b f(x,y)\,dx\,dy[/tex]
may have different finite values.
The example given above is one of those cases.
The way you would switch is by drawing a picture and seeing how that would change your bounds. Unless you are integrating to and from actual values, your inner integral goes from a function to a function, which is what you would need to adjust for.
