Question: What is the difference between e.m.f. and Potential Difference?
The discussion revolves around the differences between electromotive force (E.M.F.) and potential difference in electrical circuits. Participants explore definitions, implications, and the behavior of current in various circuit configurations.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants attempt to differentiate E.M.F. from potential difference, questioning the conditions under which each applies. Some raise concerns about the nature of current in AC versus DC circuits and the implications of equations related to instantaneous current.
The conversation is ongoing, with various interpretations being explored. Some participants provide insights into the definitions and roles of E.M.F. and potential difference, while others express confusion about the relationship between these concepts and the behavior of current in circuits.
Participants note the historical context of the terms E.M.F. and potential difference, suggesting that terminology may vary based on the field of study. There is also mention of specific equations and their relevance to AC and DC currents, indicating a need for clarity on these topics.
psykatic
What is the difference between E.M.F. and Potential Difference of a circuit?
Both have similar SI unit, that is, Volt (V)
I did find out one thing, that emf is the potential difference when there is no current flowing through the circuit or when the key is open. Whereas, the circuit has certain value of potential difference when there is current flowing through the circuit.
But, while I was going through the Chapter Electromagnetic Induction, I found one thing strange. In case of an A.C circuit containing an inductance, we have,
[tex]e=E_o~sin({\omega.t}+{\pi/2})[/tex]
and even, the instantaneous current is given by,
[tex]i=I_o sin({\omega.t)[/tex]
Where does this current come from? How can the circuit have a current flowing through when there is certain value of e.m.f?
The key to thinking about an electromotive force is the "force". It is a force that will push current along - circuit willing.
The voltage is an expression of the potential difference between 2 points. Of course if those 2 points are on each side of an emf source they will be interchangeable in that circumstance then won't they?
I didnt get you, do you mean emf is a force whereas voltage isnt? Then if it is a force, how is it experienced by the circuit? and due to what factor? There is no current flowing through the circuit, yet we have equations for the instantaneous current flowing through the circuit. How is that possible?
An emf is a source of electrical energy. Like a battery or a generator actively sources electrical flow.
Voltage is a measure of electrical potential between 2 points.
In looking at Ohms Law the sum around a loop is 0. The emf is the active element and the resistors "resist" the flow from the emf about the loop, hence voltage drops to account for the electrical energy supplied by the emf.
So, if there is an emf source in a circuit, it automatically induces current. And these currents are alternating in nature. Is it true?
Not necesassarily AC current. A DC source may be considered emf as well.
So, their maximum value doesn't change after certain phase reversal? Thats a DC, in that case what would be the equation for instantaneous current in the circuit?
What do you mean by "certain phase reversal" and "instantaneous current" ?
As in the case of a circuit having sertain emf source connected parallel to the emf, the current induced is alternating i.e in the given equation,
[tex] i=I_o sin({\omega.t)[/tex]
The value of [tex]I_o[/tex] changes with the value of the [tex]\omega.t[/tex]. If we plot a graph, the value of [tex]I_o[/tex] reaches maximum when [tex]E_o[/tex] is maximum.(i.e a sine graph, with maximum values when [tex]\theta=\omega.t =0,\pi/2, \pi ~and~ so~ on[/tex]
Have you ever seen a graph of AC current and a DC current together? AC obeys the laws you just stated. DC however is as the name implies is direct...so its graph is theoretically a straight line (that doesn't happen in absolutely all cases)
So Alternating Current...alternates and Direct Current doesn't
Well, if you really want to have an equation for DC, then look up Ohm's law for full circuit which is [itex]E[/itex] = I(R + r), hence I = [itex]E[/itex] / (R + r) where R is the resistance of all electric components in the circuit and r is the resistance of of the electricity source. This is for DC! DC implies that current flows in one direction, so without intervention (considering an ideal circuit, where energy source contains an unlimited amount of electrical energy), current, EMF, voltage across any two points of the circuit and resistance remain constants over time. So I(t) is a straight line, parallel to x-axis. I hope that helps.
Okay agreed, then what is the effective value of EMF and Current all about? I mean, 've two more equations given by,
[tex]E_rms=\frac{E_o}{\sqrt [2]}[/tex]
The book says, if the emf induces certain current in the circuit and this current generates certain amount Heat (H) in time t, then the same quantity of heat can be produced in the same circuit in the same time by passing a steady current of constant magnitude through it. The vale of such current is called the effective value or R.M.S. value.
Is this value a representation of DC? I'm terribly confused!
No the concept of RMS value is that if you can treat the AC source as though it were operating like a DC with a specified RMS value. Unlike the DC source of emf, the exact voltage supplied varies with time, so the RMS value is simply the "average" value of the AC current which could be simulated with a DC current of the same value to yield the same result. In a way, you could think of RMS value of a AC source of emf as its quasi-DC equivalent.
Gosh! This is getting on my nerve, is it that if a circuit has an emf source, it'll induce AC current and in case of certain applied potential difference, it'll induce DC?
We don't want any external emf source to induce AC current in a circuit. We have to rotate a coil with a resistance in a magnetic field.
We can't induce DC current in any circuit. Chemical reaction in a cell will produce DC current in the circuit.
Then what does this equation represent,
[tex] <br /> i=I_o sin({\omega.t)[/tex]
a D.C current or an Alternating Current, it has to be AC, but then what is instantaneous current? neither DC nor AC, then what?
A small portion of any curve is almost a straight line but a curve is not a straight line. Similarly an instantaneous current is in one direction but we won't call it as DC.
Okay, concept clear! Thank You very much everyone!
wmf is not force .its work done to move a unit + ve charge from - to + terminal of cell
xvdg ff f wsger
There is no difference. They are one and the same.
EMF is a more historical term, so is likely to be found in association with the older realms of electrical engineering, such as motors and electromagnets, where it sounds more erudite. You may find it still used in electrochemistry, too, another traditional science steeped in history.
If it were used with recent technology, such as solid state electronics, it would seem pretentious.
First of all I commend you for having such a great site. Recently I was exposed to information relating to the dangers of EMF. I am here for the purpose of trying to get as much factual information as possible.
I created a website http://protectionfromEMF.org I want to find high quality and factual sources of information that I can help educate the vistors to my site.
So here is my first question. Potential Difference while I understand what EMF means. How does Potential Difference relate to EMF. Reading the article created more confusion than clairity for me. That is not to say the thread is not accurate, it is my understanding of the subject matter is weak. Thanks so much. I look forward to a reply.
If anyone would like to visit my site and provide constructive feedback I would be very appreciative.
115KillBill
Text books are absolutely clear about the difference between emf and pd.
Emf refers to the source of electrical energy (cells, dynamoes etc).
Pd refers to the dissipation of electrical energy(resistors, motors etc)
State in an exam that there is no difference and you are on the way to being a failure in physics
It is not simply "historical terms"
in the attachment drawing one is "emf" the other is "pd".
It is essential to know the differenc to have a full understanding of electrical circuits.
Maybe you are thinking "pd" means power dissipation (units: Watt). In this thread, "PD" means "potential difference" (units: Volt).
I understand emf to mean electro- motive- force and pd to mean potential difference.
I can't remember seeing PD used any where as a general abreviation for power dissipation.
No confusion at all.
  • · Replies 30 ·
10K
