Forces related question (it's a problem)
  • Thread starter Thread starter Moontears
    Forces
The discussion revolves around a forces problem involving two coins, a loonie and a dime, connected by a thread over a smooth bar. Participants are examining the acceleration of the coins when the loonie is released, causing it to fall while the dime rises, with considerations of gravitational force and tension in the thread.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss separate systems for the loonie and the dime, analyzing forces and tension. There are questions about the significance of the gravitational constant used and whether the thread can be ignored in simplifying the problem.
Some participants have provided calculations and reasoning, with one confirming an answer that aligns with a textbook solution. Others are exploring different approaches and questioning assumptions about the system's setup.
There is a mention of significant figures in the value of gravitational acceleration, and one participant expresses uncertainty about their own calculations, indicating a potential misunderstanding of the problem setup.
Moontears
Ok, I solved this forces problem and I keep getting a different answer than presented in the back of the book. Now I am almost certain that I am correct and I just want to see if anyone else may be able to answer this problem and don't even post your solution, only what you got for the acceleration of the coins. If in the mood, please attempt.
The problem is as follows:
You attach a loonie (mL = 6.99g) and a dime (mD = 2.09g) to the ends of a thread. You put the thread over a smooth horizontal bar and pull the thread taut. Finally, you release your hands, letting the loonie drop and the dime rise. Friction between the thread and the bar is negligible, and the magnitude of g = 9.80 m/s/s [down]. Determine the magnitude of the acceleration of the coins.
cheers
Ok, let's deal with the loonie and the dime separately as two systems sharing an acceleration and a tension.
For the loonie, we know that:
a = ((mL) * g - T)/mL
This rearranges to..
T = mL*g - mL * a
For the dime, we get similarly...
a = ((T - (mD) * g)/mD
T = mDa + mDg
Now, T = T (shock horror! :smile: so
mD*a + mDg = mL*g - mL * a
so a = (mL*g - mD*g)/(mD + mL)
= 5.29 ms^-2
(However, the value you have for g is wrong. g to 3 sf = 9.81, not 9.80.)
FZ+'s point about g is that, if you are using two significant figures, 9.8 is sufficient but that, if you are using three significant figures, the correct value is 9.81, not 9.80.
Now, FZ+, why would it be incorrect to ignore the thread connecting the two coins and just treat this as a single object with mass
6.99- 2.09= 4.90 grams? Of course, such an object would just accelerate downward with acceleration 9.81 cm/sec^2.
Thank you FZ+, yeah you are getting the same answer as the back of the book. I just had another way of approaching the problem which made sense in my nogin but I guess was wrong. My way I kept getting 18.1 m/s/s, which was way off. Thank you for your time.
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 105 ·
