Speed of electron in Bohr model
The discussion revolves around the classical Bohr model of the hydrogen atom, specifically focusing on calculating the speed of an electron in its ground state orbit and determining the radius of that orbit. The problem involves concepts from atomic physics and electrostatics.
  • Participants discuss the relationship between angular momentum and the speed of the electron, questioning how to derive the radius without prior knowledge of its value. They explore the use of Newton's laws and electrostatic forces to establish equations that relate speed and radius.
Participants are actively engaging with the problem, offering various approaches to derive the necessary equations. Some have provided guidance on using the relationship between centripetal and electrostatic forces to find the radius, while others have confirmed the effectiveness of these methods in reaching a solution.
There is an indication of uncertainty regarding the force acting on the charges and the need for additional information to fully resolve the problem. The original poster expresses a limitation in not being able to use known values directly, which shapes the discussion.
vaizard
In the classical Bohr model of the hydrogen atom, the nucleus has one positive electronic charge Q_n = e = +1.602E-19 Coulombs and the single electron (mass = 9.1E-31 kg and Q_e = -e = -1.602E-19 C, one negative electronic charge) orbits the nucleus in a circular orbit. In the Bohr model, stable orbits result only when the angular momentum is an integral multiple of h/(2\pi) (remember, L = r x p, but for circular orbits r is perpendicular to p, so here L = mvr = n(h/2\pi) and h = Planck's constant = 6.626E-34 J-s.
a) Calculate the speed with which the electron must orbit the proton for the ground state (n = 1) in the Bohr model of the hydrogen atom.
b) What is the radius of this ground state orbit? You probably know from Chemistry that the atomic size is about an Angstrom (10E-10 m). Is your answer close to this?
[tex]L = mvr = \frac{nh}{2\pi}[/tex]
Not sure if this one is needed, but:
[tex]F = \frac{1}{4\pi\epsilon_0} \frac{|q_1q_2|}{r^2}[/tex]
From the first equation,
[tex]v = \frac{nh}{2\pi mr}[/tex]
I know what n, h, and m are, but I don't have r (well, I know it's .529E-10, but I can't use it). For this reason, I'm trying to use the second equation to find r from the charge values for the proton and electron, but I don't know F, the force on each charge. Any ideas?
Thanks!
Remember from circular motion that [tex]a=\frac{v^{2}}{r}[/tex].
So Newton's 2nd law can be written as [tex]F=m\frac{v^{2}}{r}[/tex]. This should help :)
Yeah, I thought of that too, but once again, you need the radius to find the force by that method.
two equations, two unknowns?
You have one equation, now use forces to get second.
will get something like
v^2 = k1/r
v = k2 /r
Well, you have Bohr'd second postulate as,
On squaring it, you'll have:
[tex]m^2v^2r^2 = \frac{n^2h^2}{4\pi^2}[/tex]
Also, from the first postulate you know that,
Centripetal Force= Electrostatic Force
Therefore you'll have,
[tex]\frac{mv^2}{r}=~\frac{e^2}{4\pi\epsilon_o r^2}[/tex]
Now, equate the [tex]v^2[/tex] terms, with their appropriate values from the above two equations, you'll get an equation for r!
I hope this proves to be of help to you. :wink:
Thanks a lot, that worked perfectly! I would have never thought of that!
When I completed part B, I got an answer of [tex]\sim 0.48 \, \AA[/tex] for the radius, which is close enough to [tex]a_0 = 0.529 \, \AA[/tex]
Well, I'm always hereto help!
