Thread Closed
Drill problem, linear speed of drill bit help plz
Share Thread Thread Tools
Jan15-09, 05:03 PM   #1
[b]1. For a 12.7mm diameter drill bit turning at a constant 1250 rev/min find a) the maximum linear speed of any part of the bit; b) the maximum radial acceleration of any part of the bit
[b]2. i switched the revs per minutes into 130.9 rads per sec but other than that i really have no clue what is going on or how to start so if anyone can give me hint as of where to start the actual problem would really appreciate it ty.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Jan15-09, 06:01 PM   #2
Recognitions:
Homework Helper Homework Help
The maximum linear speed is presumably just the speed of a point on the circumference?
So you need the circumference of the bit and the rotation rate
The angular velocity is just rate of change of angle (ie deg/sec or rad/sec)
The angular acceleration is rate of change of this with time - ie the 2nd differential.
Thread Closed
Thread Tools
Similar Threads for: Drill problem, linear speed of drill bit help plz
Thread Forum Replies
Resonance of a pneumatic drill on the the floor Engineering, Comp Sci, & Technology Homework 0
Diamond Drill Bit Question Materials & Chemical Engineering 6
Revolutions of and Electric Drill Introductory Physics Homework 2
Mastercraft cordless drill batteries General Discussion 12
Excuse Me While I Drill A Hole My Head General Math 2
