What Air Resistance Force Does a Car Face at 65mi/hr?
  • Thread starter Thread starter afg_91320
    Auto Force
The discussion revolves around calculating the air resistance force experienced by a car traveling at 65 miles per hour, given that the force varies with the square of the speed. The original poster provides initial conditions where the car experiences a force of 100 lbs at 30 miles per hour and seeks guidance on how to approach the problem without directly asking for the answer.
  • Participants explore the relationship between speed and air resistance, questioning how to set up the proportionality correctly. There are attempts to manipulate equations and clarify the concept of proportionality in relation to the square of the speed.
Some participants have provided insights into the mathematical relationships involved, suggesting ways to set up equations based on the proportionality of drag to the square of the speed. There is an ongoing exploration of different approaches, with some participants expressing confusion about their calculations and seeking clarification on the correct steps.
Participants note the importance of understanding the proportional relationship and the implications of squaring the speed in their calculations. There is a recognition of the challenge posed by similar problems, indicating a broader context of learning and application.
afg_91320
The force felt on an auto due to its movement through still air varies approx. as the square of the car's speed. (the force is also known as air resistance) assume the force varies exactly as the square of the speed. around town at 30mi/hr a car experiences an air resistance force of 100lbs. what size force would you expect the car to face while traveling at 65mi/hr?
car travels at 65mi/hr
at 30 mi/hr its air resistance force is 100 lbs.
ive been looking at this problem for the last hour, and i don't know what good the weight will help me with. I've tried conversion but it gets me nowhere. i don't want the answer, i just want to know how should i approach the problem, and how do i start!
Welcome to PF!
Hi afg_91320! Welcome to PF! :smile:
This is a dimensions problem.
So write an equation with a "proportional" sign in the middle, instead of an equals sign …
Force ~ (a function of v) …
multiply v by 65/30, and what happens? :wink:
ok-here is what i got:
65/30 = 100/v <-- equal sign means propotional
65v=3000
v=3000/65
v=46.153
but the answer in the back is 4.7 x 10^2 lb.
what did i do wrong?? :(
Remember they said the drag was proportional to v2
so that would make it:
65/30 = 100/v^2
65v^2=3000
v^2=46.153
v=6.8 <--that is incorrect.
drag is prop to v2
so drag1/drag2 =v12/v22
^^how does that help me?
this is what i did:
v1^2/v2^2=65/30
(100)^2/v2^2=65/30
65v^2=300,000
v^2=4615.384
but its still wrong!
can anyone show me the correct steps on how to do it! i have 3 more prblms similar to this! help me with this one, and ill be able to the others correctly!
First make an estimate of the answer - so you know if your calculator got it right.
65mph is a little more than twice 30mph, so since force goes up by 4 if speed goes up by 2 we expect a force of around 400-500 lb
Now d1/2 = v1^2/v2^2
d1/100 = 65^2/30^2
d1 = 100 * (65^2/30^2) = 100 * (4225/900) = 100 * 4.69 = 470 lbs
oohhh! i got it! i was just doing my math all wrong! thanks!
  • · Replies 39 ·
  • · Replies 17 ·
