Torsion Spring Catapult Velocity
The discussion focuses on designing a torsion spring catapult capable of launching a 0.15kg ball at a velocity of 35 m/sec. The user plans to utilize a 0.3m arm length from the center of the torsion coil and assumes a 45-degree angle for the launch. Participants are asked to provide specifications for the torsion spring required for this setup, indicating a potential application in building a pitching machine.
  • Torsion spring mechanics
  • Basic physics of projectile motion
  • Understanding of angular displacement
  • Knowledge of material properties for spring design
  • Research torsion spring specifications for desired force and velocity
  • Learn about projectile motion equations to calculate launch parameters
  • Investigate materials suitable for constructing a torsion spring
  • Explore designs for pitching machines utilizing torsion springs
Engineers, hobbyists, and educators interested in mechanical design, physics applications, and those specifically working on catapult or pitching machine projects.
marietta_ken
I'm trying to design a simple torsion spring catapult to launch a 0.15kg ball at a velocity of 35 m/sec at the moment of separation. The ball will be in direct contact with the unrestrained end of the spring. As a starting point, I'm planning a 0.3m length for that "arm" end of the spring as measured from the center of the torsion coil. I'm also starting with an assumption of 45 degrees of contact/throw for the arm.
Can anyone help me define the torsion spring I need?
are you building a pitching machine?
  • · Replies 20 ·
  • · Replies 19 ·
12K
  • · Replies 59 ·
15K
