Can Diffraction Occur with Significantly Narrower Apertures?
  • Context: Undergrad
  • Thread starter Thread starter Ahmed Abdullah
    Diffraction
Diffraction is observed when the width of apertures in a grating is on the order of the wavelength used. If apertures are significantly narrower than the wavelength, they behave as point sources, resulting in negligible diffraction patterns due to minimal destructive interference. Small apertures enhance the diffraction pattern, which is fundamentally an interference pattern from multiple isotropic radiators. As the aperture size decreases, the central maximum of the diffraction pattern spreads, eventually filling the space beyond the aperture.
  • Understanding of wave optics principles
  • Familiarity with diffraction and interference concepts
  • Knowledge of aperture sizes relative to wavelength
  • Basic grasp of grating theory and its applications
  • Study the mathematical derivation of diffraction patterns from single and multiple apertures
  • Explore the concept of convolution in optics for calculating diffraction patterns
  • Investigate the effects of aperture size on light propagation and interference
  • Learn about isotropic radiation and its role in diffraction phenomena
Physics students, optical engineers, and researchers in wave optics looking to deepen their understanding of diffraction and interference patterns.
Ahmed Abdullah
We know that to observe diffraction the width of the apertures in the grating must be of the order of the wave-length used. Would we observe diffraction if the apertures are significantly narrower than the order of wavelength used? Or what would be the difference?
I think we would not observe diffraction at all. Because at the mentioned case, the aperture can be considered as a point source. But I have confusions and don't have clear-cut idea about why it should be like that.
Science news on Phys.org
Don't confuse two sources of diffraction pattern. For a grating, it is actually better to have small apertures. The diffraction pattern is actually an interference pattern, and it results from the superposition of the radiation from multiple aperatures that are usually treated as isotropic radiators. A true diffraction pattern (due to diffraction) will also occur from a single aperture whose size is on the order of a wavelength. A pattern will result from a grating with apertures on the order of a wavelength, but calculating this pattern is a bit more complicated (you have to do a convolution). There should be negligible diffraction pattern from a single aperture that is much smaller than a wavelength, because there is negligible destructive interference.
As the aperture gets smaller, the central maximum in the diffraction pattern spreads out (becomes wider). When the aperture becomes small enough, the central maximum completely fills the space beyond the aperture. The aperture effectively becomes a point source of light, radiating uniformly in all directions beyond the screen.
9K
9K
