Thread Closed
Cost Implications Of Low Power Factor
Share Thread Thread Tools
Jan20-09, 11:53 PM   #1
We operate a 3 phase, 11kV network with automatic power factor correction equipment installed. Over the last four weeks we have had the PFC switched off due to an electrical incident.
How can I calculate the cost of running without PFC for this period of time, our load is fairly constant at around 2.5MW. Our manager wants to include the increased electricity cost on the insurance claim due to operating without PFC.
TIA
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jan21-09, 03:24 AM   #2
Recognitions:
A power meter that can measure power factor? Something from Fluke (345B), Amprobe, or your favourite instrumentation supplier.
Jan21-09, 05:02 AM   #3
Recognitions:
Gold Membership Gold Member
Background:
To see this from the Utility's point of view, remember what your uncorrected load is doing: forcing the Utility to supply you surplus current for the same power draw. This doesn't immediately cost them anything, unless it happens to force them to up the current rating of their distribution equipment in the locale of your facility.
Details:
You should have some idea of the uncorrected power factor from the rating on the correction equipment installed. The cost, if any, will depend on the particular utility. Typically total cost is broken down into Distribution Demand in kw (power rating of the distribution to your facility) and another part reflecting actual energy supplied. Dominion Power for instance has an 85% trigger. Stay above that and there's no penalty. Drop below it and for your Distribution Demand cost, they charge a minimum of 85% of your maximum KVA demand. If your facility's max VA demand peaks up to, say, 3000 KVA, they may charge you for 2.55MW worth of distribution regardless of actual load. If your utility invokes such a trigger it will be no doubt be reflected in the next bill as a new floor for your 'Distribution Demand' as it is called with the supply portion remaining at the 2.5MW average. The cost difference between that bill and earlier ones, with the reason indicated on the utility bill, should be easy to demonstrate for your insurer.
Jan21-09, 12:17 PM   #4
I have managed to get a look at earlier bills and there is a charge for kVAr, it varies quite a bit, but I'm expecting a big jump due to PFC being turned off. I am thinking along the correct lines?
Jan21-09, 04:41 PM   #5
Mentor
Yes, you are. The purpose of the power factor correction is to reduce the kVAr.
Jan21-09, 06:26 PM   #6
Recognitions:
Would there be a way to install a kvar-hr meter?
Thread Closed
Thread Tools
Similar Threads for: Cost Implications Of Low Power Factor
Thread Forum Replies
Does nuclear power cost massive billion gov subsidies? Nuclear Engineering 131
Estimating cost due to power (application of electric current) Introductory Physics Homework 12
power factor Introductory Physics Homework 1
