Thread Closed
electric field and rectabgle
Share Thread
Jan21-09, 12:23 PM   #1
Three positive charges are arranged in a rectangle. The charge in the bottom left corner is +5.63 nC, in the top left corner is +5.64 nC, and in the bottom right corner it is +11.28 nC. The sides have a length of 0.639 m and .213 m. Find the magnitude of the electric field at the fourth corner of the rectangle. Answer in units of N/C.
2. Relevant equations
E = kq / r^2
3. The attempt at a solution
E for bottom left : k(q) / (.67356m)^2 = 111.53 N/C
E for top left : kq/ (.213m)^2 = 1117.28 N/C
E for bottom right : kq / (.639m)^2 = 248.284 N/C
Then I drew these Electric fields on an x-y axis and they all ended up in quadrant one. So I then found the x an dy components of each. Ex total was 1196.14 and Ey total was 327.148
Finally I found the Electric field for 4th corner by using the x and y compoenents and it turned out to be 1240.07 N/C .
for some reason Im not wholly assured that my answer is correct. Can you please look over and tell me if there is anything wrong with my problem solving approach. Thank you very much =]
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan21-09, 12:32 PM   #2
sure enough I entered the answer and it was wrong =( . I am now in dire need of help
Jan21-09, 03:34 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by itryphysics View Post
Good
That's not what I get. Perhaps you should show me what you are getting for the x and y components of the field from the bottom left charge.
Jan21-09, 04:26 PM   #4
Thank you for cheking my work . My approach was correct. The way I had drawn my diagram of the charges was incorrect, which led me to make some false assumptions. For example I was using 45 degrees as my angle when i was finding components. However that is incorrect because the figure is a rectabgle not a square so instead I had to use the ratios of the sides in order to calculate my components.
Thank you once again!
Jan21-09, 04:31 PM   #5
Recognitions:
Welcome
Thread Closed
Similar discussions for: electric field and rectabgle
Thread Forum Replies
1.) Net electric field and 2.) Maximum electric field from centre of a ring Introductory Physics Homework 7
period of an electric dipole rotating in an external electric field Introductory Physics Homework 2
Electric field in a dielectric in terms of the electric field in the vacuum Introductory Physics Homework 0
Calculating Electric Potential in A Uniform Electric Field Introductory Physics Homework 4
Electric charge and fields: uniform electric field Introductory Physics Homework 1
