The cross product and dot product of vectors
The discussion revolves around the cross product and dot product of vectors, specifically focusing on the calculations involving vectors A, B, and C. Participants are attempting to solve problems related to these vector operations as part of their homework.
  • Mixed
  • Participants are exploring the calculation of the cross product and dot product, questioning their results and the methods used. Some are attempting to use matrix representations for the cross product, while others express confusion over the correct application of vector operations.
There is ongoing exploration of different methods to compute the vector products, with some participants providing corrections and clarifications on vector notation and operations. Multiple interpretations of the calculations are being discussed, and some participants have expressed uncertainty about their results.
Some participants mention constraints related to homework rules and the need for clarity in vector notation. There are indications of confusion regarding the order of operations in vector products and the implications of scalar multiplication on the results.
Xiience
http://img297.imageshack.us/img297/2527/physicsin9.jpg
i've been working with the AxB in the first one, and found that |A||B|sin(theta) = A x B, and i thought i had found my theta to be 1 degree, but i don't believe that's right. also, when i attempted to do the dot product with the C vector, i got completely lost..these are the last 2 problems on my homework, and any advice towards completely them would be so, so greatly appreciated
Thank you so much
For [itex]\vec{A}=a_1 i+a_2j+a_3k[/itex] and [itex]\vec{B}=b_1i+b_2j+b_3k[/itex]
[tex]\vec{A}\times \vec{B} = \left|<br /> \begin{array}{ccc}<br /> i & j & k\\<br /> a_1 & a_2 & a_3\\<br /> b_1 & b_2 & b_3<br /> \end{array}<br /> \right|[/tex]
okay, so using that cross product, I've got (-7.00)[C(7, -8, 0) . (-36, 72, -48)]
(7.00)(-828)
=-5796
does that look right? i believe i did the dot product right, a1b1+a2b2+a3b3
hm, that definitely does not look right.
What was your vector for [itex]6 \vec{A} \times \vec{B}[/itex] ?
(-48, 168, -54)
i think i did it wrong :( i distributed through (2i, 3j, -4k) x (-3i, 4j, 2k)
what i think my textbook said was i x j = k , ect.
i've managed to pull something up on matrices, like the way you showed it. going to try to work it out that way now
i got -9156 as my answer, and it is wrong =\
using matrices
( i j k) ( 3 4) ( 2 -4) (2 3 )
(2 3 4) ( 4 2) i - ( -3 2) j + (-3 4) k
(-3 4 2)
that led my 6(A x B) to be (132, 48, 8), then i did a1a2 + b1b2 + c1c2 with my C vector and my A x B vector, then i multiplied what i got from that by -7, and it got me -9156, and it is wrong :(
edit- those matrices look horribly sloppy, but you get the idea
This method is fine; but the way you wrote your vectors is incorrect: A=2i+3j-4k or (2,3,-4) but not (2i, 3j, -4k).
And you did end up calculating the product incorrectly.
When you distribute the cross product you need to be mindful of the order in which you write the cross products; i x jj x i...You should get:
A x B=(2i+3j-4k) x (-3i+4j+2k)= -6(i x i)+8(i x j)+4(i x k)-9(j x i)+12(j x j)+6(j x k)+12(k x i)-16(k x j)-8(k x k)=22i+8j+17k
And so 6A x B=132i+48j+102k.
Well, the last component of your 6A x B was incorrect, but that shouldn't have impacted your final answer since C has no z-component.
Still, you have somehow incorrectly calculated the dot product; 7*132-8*48=924-384=540 which does not give you -9156 when you multiply it by -7.
using matrices
(-3 4 2)
Find 6A and then cross that vector with B
kAxB is not the same as k(AxB)
i figured out the first one, and the second one my roommate got and explained it to me, he did it a really weird way, idk
thank you for all your help though!
Yes it is.
