Solve Equation for b in Mathematica | Step-by-Step Guide
  • Context: Mathematica
  • Thread starter Thread starter mutogenic01
    Mathematica
The discussion focuses on solving the equation c=(m/b)(a-(F/b))exp(-btn/m)(1-exp(-bt/m))^2 for the variable b using Mathematica. The user encountered a warning while using the `Solve` command, indicating that the expression cannot be expressed in an algebraic form. The recommended approach is to utilize numerical methods such as `NSolve`, `Root`, or `NRoot` to find a solution for b, as these functions can handle non-algebraic equations effectively.
  • Familiarity with Mathematica software
  • Understanding of algebraic equations and numerical methods
  • Knowledge of exponential functions and their properties
  • Basic grasp of programming concepts in Mathematica
  • Research the `NSolve` function in Mathematica for numerical solutions
  • Explore the `Root` and `NRoot` functions for handling complex equations
  • Study the syntax and usage of exponential functions in Mathematica
  • Learn about graphing techniques in Mathematica to visualize equations
This discussion is beneficial for mathematicians, engineers, and students who are working with complex equations in Mathematica and require assistance in solving for variables using numerical methods.
mutogenic01
Hi everybody.
I have this equation
c=(m/b)(a-(F/b))exp(-btn/m)(1-exp(-bt/m))^2 where;
a=0.14
m=4.3
F=1.88
n=integer (1-5000)
t=0.1
c=2x[(n+1)t]-x[(n+2)t]-x[nt] --- the value for x at a particular n is obtained from a graph
I have to solve for b. I have tried to solve this equation using Mathematica using the `Solve` command but there was a warning about the expression non in algebraic way.
Is there anybody out there who have any idea what function I can use in Mathematica to solve this equation? It seems easy because the only unknown is b. But I am not familiar with Mathematica so I still can`t solve it.
Thanks in advance.
Not entirely clear (I am not sure I understand your notation).
When Mathematica tells you that, it means that it can't find a way to express the answer in analytical form as a function of the variables you gave it. But you can always try for a numerical solution, using NSolve or similar (there's something like Root or NRoot, but I don't have mathematica handy right now).
  • · Replies 19 ·
