| Thread Closed |
Faraday's cage |
Share Thread | Thread Tools |
| Jan23-09, 12:42 PM | #1 |
Faraday's cage
Hi,
I've wondered if there is a possibility to create a Faraday's cage with a metallic Slinky instead of using a metallic mesh? Thanks in advanced. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jan23-09, 12:52 PM | #2 |
Mentor
| Jan23-09, 12:59 PM | #3 |
Thank you.
Actually, expanding and contracting aren't my intention. I just need to use a slinky in order to block radio waves/sound waves, which are coming out of a tape recorder. |
| Jan23-09, 01:08 PM | #4 |
Mentor
Faraday's cage |
| Jan23-09, 01:12 PM | #5 |
![]() I'm just trying to use a slinky, since I want it to be also a part of an electromagnet. |
| Jan23-09, 01:32 PM | #6 |
| Jan23-09, 01:45 PM | #7 |
I'm not sure of the spacing between the mesh, but it would probably be possible to knock holes in tin foil, unless you needed it to be more robust, then I suppose you could use thick metal? If you use tin foil of course it would be disposable so no worrying about spacing as you can just adjust the dimensions. Or I suppose you could just buy some mesh to order.
| Jan23-09, 04:46 PM | #8 |
Thank you The Dagda, I'll consider it.
randeezy, why do you say it is taking one step forward and two steps back? |
| Jan23-09, 05:13 PM | #9 |
Mentor
BTW, Aluminum foil is lousy for shielding material. There is no good way to make electrical contact, either from it to ground, or between edges or multiple pieces of Al foil. To make a good Faraday cage, you need good electrical contact between all sides/surfaces of the enclosure. You can't weld or solder edges of Al foil together, and there is a coating on it apparently that makes pressure contacts not work reliably. A much better choice if you want to solder up a good cage, is Shim Brass. You can get it at the hardware store in various thicknesses, and it's easy to cut with tin snips into the shapes that you can then solder the seams on, to form a good shield structure. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Faraday's cage
| charge.E field and Faraday's cage | Classical Physics | 19 | ||
| Faraday Cage | Introductory Physics Homework | 6 | ||
| Bird in a cage | Introductory Physics Homework | 8 | ||
| Faraday cage | General Physics | 3 | ||
| faradays cage | Electrical Engineering | 3 | ||
