Thread Closed
Electromagnetic wave reflects off a surface at a 90 degree angle. Standing wave?
Share Thread Thread Tools
Jan24-09, 10:41 AM   #1
What happens when an electromagnetic wave reflects of a surface at an 90 degree angle and continues moving along the same path as it came from?
Will the two waves that are moving in opposite direction interfer with each other to from a standing wave pattern?
This seems to be the case when you tie one end of a string to something and then move the other end to form a wave like pattern. After having reflected the 2 waves create a standing wave.
I doubt this happens with electromagnetic waves, but I have no to way to test it. Can electromagnetic waves form standing waves under any conditions?
Thank you.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan24-09, 11:05 AM   #2
Electromagnetic waves do interfere. This is the reason the double slit interference pattern occurs on a screen when the two coherent sources are focused. Also, this interference principle is used to produce antireflection and high reflecting coatings, and narrow bandpass optical filters (the optical fiber system this information was transmitted on and received by you is in part due to optical filters). Yes, an electromagnetic wave can be a standing wave, for example, in a laser cavity.
Sep27-09, 12:57 AM   #3
Do you mean to say, a EM (plane wave) at normal incidient angle with a boundary ?
Yes. There would be standing wave as explain by Fresnel reflection and refraction.
Thread Closed
Tags
electromagnetic wave, standing wave, wave equation
Thread Tools
Similar Threads for: Electromagnetic wave reflects off a surface at a 90 degree angle. Standing wave?
Thread Forum Replies
Standing Wave Introductory Physics Homework 0
Standing Wave Accelerators Vs Travelling Wave Accelerators Engineering, Comp Sci, & Technology Homework 0
Standing Wave? Introductory Physics Homework 2
Standing Wave Introductory Physics Homework 4
standing wave General Physics 2
