| Thread Closed |
Pipe Pressure |
Share Thread |
| Jan24-09, 11:07 AM | #1 |
Pipe Pressure
A fluid of density (rho) flows through a horizontal pipe with negligible viscosity. The flow is streamline with constant flow rate. The diameter of the pipe at Point 1 is d and the flow speed is v. If the diameter of the pipe at Point 2 is d/3, then the pressure at Point 2 is?
Bournalli's Equation (sp). I ended up getting P2=P1 - 40(rho)v^2. Correct? |
| Jan24-09, 01:45 PM | #2 |
Recognitions:
jan2905: That is correct; p2 = p1 - 40*rho*v^2.
| Jan24-09, 03:00 PM | #3 |
would this mean that if i were hit with the liquid at the respective points....
p1 would hurt more than p2? that would mean that a large mouth waterhose has more force than a small mouth.... that is not correct though. |
| Jan24-09, 05:06 PM | #4 |
Recognitions:
Pipe Pressure
jan2905: I think water exiting a small-mouth water hose at point 2 would probably hurt more, because it has a much higher velocity than the water at point 1. Both streams would be at atmospheric pressure immediately upon exit from the nozzle.
| Jan25-09, 06:50 PM | #5 |
but we deduced that p1 would have more pressure therefore hurting more. this math seems to be counterintuitive.
| Thread Closed |
Similar discussions for: Pipe Pressure
| Pressure in Pipe | Introductory Physics Homework | 0 | ||
| Water Pressure in a Pipe | Introductory Physics Homework | 1 | ||
| reducing pressure in a pipe | Introductory Physics Homework | 3 | ||
| 15.6 pressure in a pipe | Introductory Physics Homework | 4 | ||
| Pressure in a tank/pipe | Introductory Physics Homework | 2 | ||
