Kite string force, negative or positive>
The discussion focuses on resolving the components of a 12-lb force exerted by a kite string at a 45-degree angle to the horizontal. The horizontal and vertical components can be calculated using the Pythagorean theorem, resulting in values of 12*sqrt(2) for both components. The tension in the string is directed towards the person holding it, leading to a negative vertical component and a variable horizontal component depending on the observer's position. The primary takeaway is that while the magnitude of the forces is always positive, the direction determines the sign of the components.
  • Understanding of vector components in physics
  • Familiarity with the Pythagorean theorem
  • Knowledge of force directionality and tension in strings
  • Basic trigonometry, specifically angles and their effects on force components
  • Study vector resolution techniques in physics
  • Learn about tension forces in different contexts
  • Explore the application of the Pythagorean theorem in real-world scenarios
  • Investigate the effects of angles on force components in various physical systems
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of force resolution and vector analysis in practical applications.
2clients
A kite string exerts a 12-lb pull (|F|) on a kite and makes a 45 degree angle with the horizontal. Find the horizontal and vertical components of F.
Pythagorean
12*sqrt(2) for both horizontal and negative
My question is whether to assign a positive or negative to either value? It seems that either could work with the limited assumptions in the question? Or would it be more appropriate for the y force to be negative?
Hi 2clients, well actually this really does depend. When you have a taught string, as we have in your question, there is a tension in the string. Now this tension can be model as acting in both direction along the string. Imagine for example you help a piece of sting in your hands and pulled both ends, there is a force stopping both hands move further apart when the string is taught, so there must be a force acting on you right had to the left, and you left hand to the right :D
So what you need to ask is in which direction do you want the tension to be acting for the purpose of you question. In the question its says it exerts a pull on the kite, so the tension will be acting down the sting towards the person holding the sting, acting away from the kite, so it will have a negative y value and and may have a negative or positive x value depending on where the person is standing relative to the kite :D
That all said, most question wouldn't ask you to work out negatives and posatives, and they will simply want to know the magnitude of a force or the magnitude of its components, which are always positive :-) hope that helped
ps sorry if you knew most of that already, obviously I don't know what you already know :D
  • · Replies 31 ·
  • · Replies 18 ·
