Astrophysics - Apparent Magnitude of stars in a close binary system
The apparent magnitude of a close binary system consisting of two solar-type stars, each with an individual apparent brightness of m = 10 mag, is calculated to be approximately 4.25 mag when both stars are combined and not resolved. The calculation utilizes the formula m1 - m2 = -2.5 log(f1/f2) to determine the combined brightness. The discussion also addresses the minimum brightness during eclipses at 100%, 75%, 50%, and 25% coverage of the stellar surface, emphasizing that a change in brightness corresponds to a change in magnitude of less than 1 mag when two stars are involved.
  • Understanding of apparent magnitude and its calculation in astrophysics
  • Familiarity with logarithmic functions and their application in brightness calculations
  • Knowledge of binary star systems and their characteristics
  • Basic grasp of eclipsing binaries and their effects on observed brightness
  • Study the concept of logarithmic scales in astronomy, particularly in relation to brightness
  • Learn about the properties and dynamics of eclipsing binary systems
  • Investigate the effects of varying surface coverage on the apparent magnitude of stars
  • Explore the use of photometric measurements in determining stellar brightness
Astronomy students, astrophysicists, and educators seeking to deepen their understanding of binary star systems and the calculation of apparent magnitudes in astrophysics.
goldilocks
2 solar type stars are in a close binary system. Each indivual star has an apparent brightness of m = 10 mag.
Determine the apparent magnitudes of the combined system of the 2 stars assuming they cannot be resolved as individual objects. Determine the minimum brightness for this eclipsing binary when 100%, 75%, 50% and 25% of the stellar survace are covered during the eclipse.
m1 - m2 = -2.5 log (f1/f2)
10-10 = -2.5log(f1/f2)
f1/f2 =1
f1=f2
m1+2 - m2 = -2.5 log (f1+f2 \ f2) f1 = f2
m1+2 - m2 = -2.5 log (2f1 \ f1)
m1+2 - m2 = -2.5 log 2
m1+2 = -2.5log2 + 5 mag
m1+2=4.247425011
m1+2 = 4.25 mag
Then I'm not sure how to continue from here - any help would be most appreciated!
One magnitude represents a change in brightness of a factor of around 2.5
so if you double the brightness (ie two stars) the apparent mag of the combination is only going to change by less than 1mag
