Effect on Flow measuring device due to turbulent flow of air
The discussion centers around the effects of turbulent air flow on flow and pressure measurement devices, particularly in the context of using vacuum pumps and various tubing configurations. Participants explore the implications of turbulence on mass flow measurement and seek methods to mitigate its effects.
  • One participant questions whether turbulent flow affects mass flow measurement and seeks ways to reduce turbulence effects.
  • Another participant asks for details about tube sizes and fluid speeds, suggesting that turbulence reduction may not be feasible under certain Reynolds number conditions.
  • A participant argues that turbulent flow may actually be beneficial for measuring velocity, as it could provide a more uniform velocity profile compared to laminar flow.
  • Discussion includes the principle of operation of a mass flow sensor using a heated thermoresistor, with an assumption that laminar flow allows for more accurate measurements.
  • One participant identifies the device being discussed as a hot wire anemometer and mentions the importance of calibration curves for accurate measurements across different velocity ranges.
  • Another participant reiterates that turbulent flow leads to a more uniform velocity profile, despite potential fluctuations at single points in time.
Participants express differing views on the impact of turbulent flow on measurement accuracy, with some suggesting it is beneficial while others raise concerns about its effects. The discussion remains unresolved regarding the best approach to handle turbulence in flow measurement.
Participants reference specific parameters such as tube diameter and maximum velocity, but there are unresolved assumptions about the conditions under which turbulence affects measurements. The discussion also touches on the mathematical modeling of velocity profiles without reaching a consensus on the implications.
This discussion may be of interest to engineers and researchers involved in fluid dynamics, instrumentation, and those working with flow measurement devices in experimental setups.
Prasannak
effect on Flow and pressure measuring due to turbulent flow of air
Hi,
I want to measure the air flow rate using a device which will basically measure the velocity of air and converts that in terms of flow rate reading. For creating flow of air i have used vacuum pumps which is connected by using the L connector and T connectors with the tubings. In this test, i am worried about the turbulent flow in the L connector and T connectors , which can effecting in flow measurement because measurement of flow rate in terms of velocity. What i exactly wanted to know is whether turbulent flow effects the mass flow measurement? if yes, how to reduce the turbulence effect?
Thanks in advance for the answers.
First, what size are your tubes and what speeds are fluids? In many cases people talk about reducing turbulence when Reynolds numbers just aren't very condusive for that.
Also, many flow meters measure mass or volume flow, how exactly are you getting velocity?
Offhand, I would think you would want the flow to be turbulent. If you are measuring velocity at a point in the stream, and it's not turbulent, then there is a large velocity profile of which you could possibly measure.
Thanks for the respons.
Tube dia= 40mm, Maximum velocity= 30m/sec
Principle of working of mass flow sensor:
An electrically heated thermoresistor
is kept at a constant higher temperature relative to the
medium (CTD mode). The heat dissipation into the medium
increases with the increasing mass flow. The heater voltage is
thus a direct measure of the standard flow velocity.
My assumption is, In laminar flow all the particles move in same velocity and the accurate measurement can be achieved. Please explain me how the turbulent flow helps in this application?
Basiccally, I need to test the component with the constant pressure difference @ the inlet and outlet. My pressure measuring device will measure the pressure @ single point. Due to turbulent flow pressure @ every point is different. Please let me know how to overcome this effect..
What you're describing is a hot wire anemomenter. Are you making your own? If not, manufactures provide calibration curves to help account for variations in the run range and what heat transfer phenomena are happening at what velocities. You may have to pick a meter that is suited for your particular velocity range.
Yes, I am very aware at how those sensors work, velocity is backed out though; the real measurement as I mentioned is mass flow. ANYWAYS, your low will more than likely be turbulent anyways, however this is good. Laminar flow gives a velocity profile where the velocity at the center is much higher than the rest of the flow. Maybe someone has the equation, but IIRC, the velocity profile is exponential, i.e.
[tex]u(y) \propto U_{max}\left(\frac{y-h}{h}}\right)^2[/tex]
You will get a more uniform velocity profile as the flow is tubulent. You are correct that the velocity at a single point will be slightly unsteady in time, however, time averaged will yield a more uniform velocity profile and laminar.
See the image here:
http://www.engineersedge.com/fluid_flow/flow_velocity_profiles.htm
See the image here:
Thank U very muchhhh...
