Can Convergent Upper and Lower Riemann Sums Establish Integrability?
  • Thread starter Thread starter jdz86
    partitions
The discussion centers on proving the integrability of a bounded function f:[a,b] → ℝ, given that the sequences of upper sums {U_{P_{n}}(f)} and lower sums {L_{P_{n}}(f)} converge to the same limit L. The key concept is that the difference between these sums, defined as a_{n} = U_{P_{n}}(f) - L_{P_{n}}(f), approaches zero as n tends to infinity. This establishes that a single value exists between the two sequences, confirming that f is integrable on the interval [a,b].
  • Understanding of Riemann sums and their definitions
  • Knowledge of bounded functions in real analysis
  • Familiarity with sequences and limits in calculus
  • Concept of integrability in the context of Riemann integration
  • Study the properties of Riemann integrable functions
  • Learn about the convergence of sequences in real analysis
  • Explore the relationship between upper and lower sums in integration
  • Investigate examples of functions that are not Riemann integrable
Students of real analysis, mathematicians interested in integration theory, and educators teaching Riemann integration concepts.
jdz86
Suppose f:[a,b] [tex]\rightarrow[/tex] [tex]\Re[/tex] is bounded and that the sequences {[tex]U_{P_{n}}[/tex](f)}, {[tex]L_{P_{n}}[/tex](f)} are covergent and have the same limit L. Prove that f is integrable on [a,b].
[tex]U_{P_{n}}[/tex](f) is the upper sum of f relative to P, and [tex]L_{P_{n}}[/tex](f) is the lower sum of f relative to P, where in both cases P is the partition of [a,b].
Also a hint was to examine the sequence {[tex]a_{n}[/tex]} where [tex]a_{n}[/tex] = [tex]U_{P_{n}}[/tex](f) - [tex]L_{P_{n}}[/tex](f)
Didn't figure out the full proof, only parts:
I started with having P = {[tex]x_{0}[/tex],..., [tex]x_{n}[/tex]}, where [tex]x_{0}[/tex] = a, and [tex]x_{n}[/tex] = b. And given that they are both convergent and have the same limit, using the hint I can show that they both converge to [tex]a_{n}[/tex], but I got stuck after that.
It's integrable if a single value exists between the two sequences as n tends to infinity, right? I'd look at this as a nested sequence of intervals, where the length of the nth interval as n approaches infinity is 0 (because the two sequences have the same limit), and from there it should be easy.
  • · Replies 17 ·
  • · Replies 26 ·
