Calculating Area of Enclosed Region
  • Thread starter Thread starter vipertongn
    Area
The discussion revolves around calculating the area of the region enclosed by the equations x + y^2 = 42 and x + y = 0. Participants are exploring the setup of integrals necessary for finding this area.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods for setting up the integral, including the use of vertical and horizontal area elements. There are attempts to determine the limits of integration and the need for a graph to visualize the region.
Some participants have provided guidance on the correct setup for the integrals and the importance of identifying the limits of integration. There is an ongoing exploration of the correct approach, with multiple interpretations being considered.
Participants mention the need for a graph to accurately determine the limits of integration and clarify the relationships between the equations. There are indications of confusion regarding the calculations and the correct application of the Fundamental Theorem of Calculus.
vipertongn
x + y^2 = 42, x + y = 0
Find the area of the region enclosed.
Integral of the top to the bottom.
At first I tried to use S sqrt(42-x)+x dx and i get -2/3 (42 - x) ^ (3/2) - 1/2 x^2
However when I set them equal to one another 42-x=x^2 and get the root values -6 and 7. Plugging it in doesn't get me the right answer...what am I doing wrong?
Your first antiderivative looks right, but the second (and easier) one is off by a sign. It should be +1/2 x^2.
You should be working with limits of integration (a definite integral) if you want to come out with a number. To get the limits of integration you absolutely need a graph of the region. Have you done this?
You have two choices on how you can set up the integral: using vertical area elements or using vertical area elements. If you use vertical area elements, the top of each area element will always be y = +sqrt(42 -x), but the bottom of the elements are different depending on whether -7 <= x <= 6 or 6 <= x <= 42. In the first interval I listed, y = -x. In the second interval, y = -sqrt(42 -x). This means you need two definite integrals, set up like so:
[tex]\int_{-7}^6 f(x)dx + \int_{6}^{42} g(x)dx[/tex]
An easier way is to use horizontal area elements. The area of a typical area element is [itex][-y^2 + 42 - (-y)]\Delta y[/itex], and you need only one integral, and it's much easier to integrate.
That makes sense, I can't get a picture of what it looks like though, however, what intervals would i use for the y then?
I set the x's equal to one another...
then I make it like -y^2+42+y and the values would be 6 and -7, but that isn't the case...I Plug them in and I end up with 119.6 and that's not the right answer.
You need a graph of the region to be able to get the limits of integration.
x + y^2 = 42 ==> y^2 = -x + 42 ==> y = +/-sqrt(-(x - 42))
You can graph this relation, can't you?
Concerning the work you show, you have
x = -y^2 + 42
x = -y
==> -y^2 -y + 42 = 0 ==> y^2 + y - 42 = 0
Solving this quadratic gives you y = -7 or y = 6.
These are the y values at the points of intersections of the two graphs. You can use either equation to find the corresponding x values.
In your first post you attempted to find an antiderivative of something, and then you apparently substituted y = -7 and y = 6 into the antiderivative. That makes no sense, which is why you didn't get the right answer.
So I should find the x values to get the intervals used in the FTC for -y^2+42+y. i recall its integral right minus leftt and isn't that how I should do it. I'm not sure what I am doing wrong still...
No, if you go with the easier tactic I described in post #2, you need the y-values at the two intersection points.
For my typical area element, the length (horizontal) is from the x value on the line to the x value on the parabola. The width (vertical) is [itex]\Delta y[/itex]. What is the interval along which the [itex]\Delta y[/itex]'s run?
Have you graphed the area yet?
I know it willl havea parabola at the top and a line underneath.
  • · Replies 27 ·
