How can pressure and volume affect the work, energy, and heat of helium gas?
The discussion revolves around a problem involving helium gas in a cylinder, focusing on how pressure and volume changes affect work, energy, and heat during an expansion process. The initial conditions are specified as 1 liter of volume and 1 atm of pressure, with a final volume of 3 liters. Participants explore the relationship between pressure and volume, particularly how pressure is said to rise in direct proportion to volume.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the mathematical relationships between pressure and volume, with some suggesting the use of a proportionality constant (k) to express pressure. There is also an exploration of the implications of the problem's wording regarding final pressure and volume.
The discussion is ongoing, with participants questioning the assumptions about the final pressure based on the problem's conditions. Some have provided guidance on using the proportionality constant k, while others are seeking clarification on the implications of the given values.
There is a noted ambiguity regarding the final pressure, as the problem states that pressure varies directly with volume but does not explicitly provide a final pressure value. This has led to differing interpretations among participants.
pentazoid
Imagine some helium in a cylinder with initial volume of 1 liter and an initial pressure of 1 atm. Somehow the helium is made to expand to a final volume of 3 liters, in such a way that its pressure rises in diect proportion to its volume.
a) calculate the work done on the gas during this process , assuming that there are no "other" types of work being done.
b) Calculate the change in the helium's energy content during this process
c) calculate the amount of heat added to or removed from the helium during this process
d) Describe what you might do to cause the pressure o rise as the helium expands
W=-integral(from V_i to V_f) P(V) dV (quasistatic)
W=-P*delta(V)
delta(U)= W+Q
delta(U)=f/2*NkT
a) P=m*V+ b , where m is the slope and b is the y-int.
m=delta(P)/delta(V)= (3-1)/((3-1)=1 and b=0
P=V
W=integral (from 1 atm to 3 atm) (V dV)
b) delta(U)=f/2*NkT=(f/2)*PV
c)delta(U)=Q+W==> Q=delta(U)-W
d) some source of external heat such as a flame is probably causing the balloon to expand
Did I do everything correctly?
P is directly proportional to V so
P = kV
where k is a constant.
Use this value for P in the work equation and integrate.
P = kV
Are my remaining solutions to the rest of my problems correct?
I thought k would just equal 1 since when you find the equation for P, P=V
The value k is a proportionality constant. One must know initial and final values of V and P to determine k. Since this was not given, the value k is unknown. Your answers will be in terms of k.
but the initial and final values of P and V were given in the problem. here is a quote from the question. :"Some how the helium is made to expand to a final volume of 3 liters , in such a way that its pressure rises in direct proportion to its volume". So if my volume rises to 3 liters, then my pressure should rise to 3 atm.
Please indicate what the final pressure is according to problem. There is no final pressure stated from what is given, only that the pressure varies directly with the volume.
The problem doesn't state what the final pressure is. It just says that pressure varies in direct proportion to its volume. The problem says that there is an initial volume of 1 liter and an initial pressure of 1 atm. Since the pressure rises in direct proportion with its volume, if the final volume is 3 liters, doesn 't that mean the final pressure is 3 atm.
No, it does not imply the final pressure is 3 atm. So, use k instead. Recall, k is the slope of the line in this case and two points are required to determine the slope of a line; you do not have the P coordinate of the second point.
