| Thread Closed |
Temperature of Bulb Filament |
Share Thread | Thread Tools |
| Feb1-09, 12:05 PM | #1 |
A common flashlight bulb is rated at 0.3 A and 3.3 V (the values of current and voltage under operating conditions). If the resistance of the bulb's tungsten filament at room temperature (20.0 degrees Celsius) is 1.10 Ohms , estimate the temperature of the tungsten filament when the bulb is turned on. Take the temperature coefficient of resitivity for tungsten to be 4.5e10-3 2. Relevant equations R = V/I 3. The attempt at a solution R = 3.3V / 0.3A = 11 Ohms when turned on Little lost on how to find the temperature when turned on. |
| Feb1-09, 12:33 PM | #2 |
Recognitions:
What are the units on that coefficient of resistivity? Perhaps we can make up a formula relating it to temperature and resistance.
| Feb1-09, 01:00 PM | #3 |
I'm curious about a custom I see universally in this forum. It's been quite a few years since I was in school and I wonder if this custom indicates a change in the way EE is being taught nowadays. Traditionally E instead of V has been used to represent electromotive force just as I represents current instead of A. In the past a distinction has been made between the unit of electromotive force and its designator.
Are instructors and textbooks now using V for electromotive force? |
| Feb1-09, 01:11 PM | #4 |
Recognitions:
How much does the resistance of the filament change?
With that Δ in resistance perhaps you can figure the Δ in temp needed to develop that much resistance? |
| Feb1-09, 01:35 PM | #5 |
Recognitions:
| Feb1-09, 01:40 PM | #6 |
Problem is ez.
You have found the R. That's good! Look at this website to know more about the coefficent. You will figure out. http://hyperphysics.phy-astr.gsu.edu...ic/restmp.html |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Temperature of Bulb Filament
| light bulb filament | Calculus & Beyond Homework | 2 | ||
| thickness of bulb filament affect brightness? | General Physics | 10 | ||
| Finding the temperature of light bulb filament? | General Physics | 2 | ||
| Light bulb filament question | General Physics | 1 | ||
| Need help on this! Light bulb Filament Temperature with emissivity and δ given | Introductory Physics Homework | 1 | ||
