Some simple Differential Equation questions [Please help]
This discussion focuses on key concepts in differential equations, specifically separable equations, direction fields, exact equations, and linear ODEs, both homogeneous and non-homogeneous. Participants clarify that a linear equation must conform to the standard form y' + p(x)y = r(x), where p(x) and r(x) are functions of x or constants. Homogeneous equations are defined as those expressible in the form y' = f(x,y) with a consistent degree across terms, while non-homogeneous equations include a non-zero r(x). Additionally, resources such as MIT's OpenCourseWare are recommended for understanding direction fields.
  • Understanding of differential equations, including separable and exact equations.
  • Familiarity with linear ODEs and their classifications (homogeneous vs. non-homogeneous).
  • Basic knowledge of direction fields and isoclines.
  • Ability to manipulate and rewrite equations into standard form.
  • Study the characteristics of linear and non-linear differential equations in detail.
  • Learn about homogeneous and non-homogeneous equations with practical examples.
  • Explore methods for constructing direction fields, focusing on isoclines.
  • Review MIT's OpenCourseWare lectures on differential equations for visual aids and deeper understanding.
Students enrolled in differential equations courses, educators teaching these concepts, and anyone seeking to deepen their understanding of ODE classifications and graphical representations.
integrate
Hi,
I am taking a course in differential equations.
So far we have learned the following topics/methods:
- Separable equations
- Direction fields
- Exact equations
- Linear ODE's - Homogeneous & Non-Homogeneous equations
1. How do you know if an equation is linear or non-linear. What is the quickest way to tell?
>> In order to be linear, does it have to have the form: y' + p(x)y = r(x) (Known as the Standard Form). Where p(x) and r(x) are functions of x only or constants?
2. When y' + p(x)y = 0; where r(x) = 0. Is this a Homogeneous equation? Why?
3. When y' + p(x)y = r(x); where r(x) is a function of x only or a constant. Is this a Non-Homogeneous equation? Why?
4. Finally, can someone explain a methodical way to draw direction fields for a given ODE. It has something to do with isoclines. When you draw the direction fields you get tangents (slope lines) which define the direction of the solution curves y(x). Can someone give me an idea how to do this with an example.
Thanks.
1. More or less...it has to have the format:
A(x)d^n +An-1(x)d^n-1...=F(x)
They'll probably only make you know this enough to put an equation into Standard Form that may not initially "appear" to be in Standard Form.
2. A homogeneous equation will be in the form of y'=f(x,y) where the right side can be expressed as a function of the ratio y/x alone...one way that usually works as a check is to see if the sum of the powers are the same for each term.
So: x^3 + x^2y = f(x,y) Both terms add up to degree 3 (3 and 2+1=3)
I've also seen its definition written like; A homogenous equation is an equation that can be rewritten into the form having zero on one side of the equal sign and a homogeneous function of all the variables on the other side.
I shy away from any official "definition" for a mathematical term...if you give an absolute for something involving math...a math guy will show you where you're wrong. ..lol3. r(x) is a function of x only.
4. There should be some examples in your book. My diff eq professor spent about 5 minutes with direction fields...said they were nice to know...and then told us he wouldn't be testing us on them. So, fearful that I may learn something I don't need to know, I never paid attention. lol
I believe MIT's opencourseware for differential equations with Arthur Mattuck shows field lines in some detail the first lecture. You can find them on youtube.
  • · Replies 0 ·
