Thread Closed
current produced by 3.5 L car engine
Share Thread Thread Tools
Feb1-09, 04:35 PM   #1
how can i determine how many amps are generated by a typical automobile engine? how many amps can i suck off of a car battery while the car is running, and not slowly drain the battery of its power?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Feb1-09, 10:52 PM   #2
Mentor
The alternator probably has an output rating.
Feb2-09, 12:36 AM   #3
You might get a rough idea by looking at the ammeter of a car that has one. Headlamps are the largest drain, I believe.
Feb2-09, 07:54 PM   #4
Quote by Gdarnall View Post
Modern automotive alternators are commonly rated at least 50 to 80 amps however, they aren't intended to provide this range of current output for lengthy durations, so be mindful that you could end up damaging the alternator/rectifier/regulator if you intend to draw near max current for any extended durations. Even so, you should check the specs for your alternator's current output.
Additionally, if you're going to be drawing high instantaneous currents, transients can prove damaging to the vehicle's expensive electronics. Just keep that in mind...
Thread Closed
Thread Tools
Similar Threads for: current produced by 3.5 L car engine
Thread Forum Replies
Force produced by current carrying coil to move sludge(steel rod) Electrical Engineering 5
Work Done By Engine/Heat Engine Mechanical Engineering 3
Current produced by rev of electron Introductory Physics Homework 3
