Differential Amplifier Common Mode Problem
The discussion centers around the operation of differential amplifiers (DAs), particularly focusing on the common mode scenario where the same AC voltage is applied to both input terminals. Participants explore the relationship between DC and AC values of currents and how they affect the calculation of the emitter resistance (Re) in AC analysis.
  • One participant expresses confusion regarding the interchangeability of DC and AC values in the context of calculating Re, questioning how DC values are used in AC analysis.
  • Another participant clarifies that Re is dependent on the DC value of the emitter current (Ie) and explains that it is derived from the slope of the I-V characteristic curve at a specific operating point.
  • A participant notes that while Re is calculated using DC values, the AC analysis uses small signal parameters, indicating that the AC current (ib) is distinct from the DC base current (Ib).
  • It is suggested that the effect of the AC signal on Re is minimal as long as the AC deviation is small, but larger AC signals can lead to nonlinear behavior and distortion.
Participants generally agree on the dependence of Re on the DC bias current, but there is some uncertainty regarding the implications of AC signals on Re and the extent of their effects. The discussion remains unresolved regarding the precise conditions under which these effects become significant.
The discussion highlights the complexity of modeling the base-emitter junction and the non-linear characteristics of the I-V curve, which may affect the interpretation of small signal analysis in the context of differential amplifiers.
chaoseverlasting
There are a couple of things I don't understand about the DA in general and when we use it in the common mode in particular (same input ac voltage to both input terminals). I am using Electronic Circuit and Theory by Louis Nashelsky and Robert Boylstad (p.591 for DA).
When we set the operating point, we do it using DC voltages which sets the values Ic, Ib and Ie.
In the ac analysis, however, we use the values of AC voltages to calculate the voltage across the output resistor. For the re model of the transistor, the value of re in the ac domain is calculated by [tex]r_i=\frac{26mv}{I_b}[/tex] where Ib is the ac current.
However, [tex]r_e=\frac{26mv}{I_e}=\frac{26mv}{\beta I_b}=\frac{r_i}{\beta}[/tex] is calculated using the DC value of Ie.
How is that possible? The DC and AC values of currents are bound to be different, but they are used interchangeably!
I thought that the net current would be the ac+dc values of the current (eg. Ie net=Ie ac + Ie dc).
Sorry for the long post, I couldn't help it.
Anyone? Please?
The Re value is dependent upon the dc value of current. The base-emitter junction, herein b-e jcn, has an logarithmic/exponential V vs. I (I vs. V) characteristic. Modeling the b-e jcn as a resistor is not valid under general large signal conditions. Re is a small signal value taken as a tangent to the I-V curve at a specific value of Ie. Ie, Vbe, & Ib denote dc values, & ie, vbe, & ib denote small signal ac values.
Since the curve is non-linear, the tangent slope changes depending on where you are on the I-V curve. Hence Re, which is the slope of V vs. I, or the inverse slope of I vs. V, varies with the dc value Ie. At larger values of Ie, the slope increases, and Re decreases.
Hence a larger Ie, emitter dc value or bias, results in a smaller Re which is an ac value. Have I explained it well? I used to be an adjunct professor of electronics, and I used Boylstad's texts.
Claude
So we basically ignore the ac signal while setting the Re value, and this value depends on the dc bias.
Then the current we measure using the ac analysis is not Ib but ib (the ac current), and for this current Re is just a simple resistor. Also this current does not have any effect on Re whatsoever... is that right?
Only a slight effect, too small to worry about as long as the ac deviation is small. When the b-e jcn deviates from its steady state operating point, the slope of the I-V curve changes, hence Re changes. If the ac signal is not small, but large, then Re changes with the signal, and this modulation of Re results in nonlinear gain and consequently distortion.
Claude
20K
  • · Replies 24 ·
29K
