csnsc14320
- 57
- 1
Mass m is attached to a post of radius R by a string. Initially it is a distance r from the center of the post and is moving tangentially with speed [tex]v_o[/tex]. There are two cases: In case (a) the string passes through a hole in the center of the post at the top, while the string is gradually shortened by drawing it through the hole, and case (b) the string wraps around the outside of the post.
What quantities are conserved in each case? Find the final speed of the mass when it hits the post for each case.
So, for case (a):
Angular momentum is conserved: [tex]I_o \omega_o = I_f \omega_f[/tex]
[tex]m R^2 \frac{v_o^2}{(R)^2} = m r^2 \frac{v_f^2}{r^2}[/tex]
Solving for [tex]v_f[/tex] we should get the right answer.
Now, case B is where I'm stumped. My initial thought is that angular momentum is conserved again, but then I end up with the exact same case I have in (a). Does the fact that the mass is rotating about the circumference of the rod, as opposed to the center of the rod, affect the speed of the mass? And, if so, how would I get started on how to find that?
