Repairing a rear-screen projection TV
  • Thread starter Thread starter DaveC426913
    Projection
The discussion revolves around the potential repair of a Toshiba 42H82 rear-screen projection TV that is exhibiting issues such as wavy lines on the screen. Participants explore various possible causes and repair strategies, emphasizing the complexity and risks involved in TV repairs.
  • One participant suggests that the issue may be related to a capacitor failure, referencing similar problems reported by others with Toshiba projection TVs.
  • Another participant proposes that the problem could be a sync issue, particularly horizontal sync, and mentions the possibility of finding a burst capacitor through inspection.
  • A different contributor notes the historical practice of reflowing solder joints to address cold solder joints, although they express uncertainty about its applicability to newer surface mount components.
  • Safety concerns are raised regarding the use of isolation transformers and the dangers of high voltages held on capacitors, emphasizing the need for caution when repairing TVs.
  • One participant mentions the importance of having a SAMS Photofacts for the TV model to aid in repairs, although they note that such documentation may not be available for this specific model.
  • Another participant highlights the potential risks of replacing components, warning that improper soldering can damage adjacent components and suggesting careful handling of expensive parts like the projection illumination bulb.
Participants express a range of views on the potential causes of the TV's issues and the methods for repair. There is no consensus on a single solution, and multiple competing hypotheses are presented regarding the nature of the problem and the best approach to repair.
Participants acknowledge the complexity of diagnosing and repairing electronic devices like TVs, with discussions highlighting the need for technical knowledge and caution due to the risks involved.
DaveC426913
2025 Award
I've got this Toshiba 42H82 TV that the cat dragged in. Attached is a quick rough pic of what it's doing. I know it's difficult (and potentially dangerous) to repair a TV and wouldn't attempt to do it without a friend who knows his electronic repairs.
Can this kind of thing be repaired? Ideas?
I had asearch for projection screen and wavy lines and it looks like a capacitor failure on one of the boards from what some other people have said.
http://www.fixya.com/support/t294387-toshiba_50h12_rear_projection_tv_wavy
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Toshiba-Projection-Wavy-Lines.htm
Seems to occur to 4 year old Toshibas a lot. I'd still seek professional opinion however.
no really a tv repair person myself, but it sort of looks like a sync problem. horizontal at least, and vert if it's "rolling". if you can find a burst capacitor by inspection, consider yourself a very lucky nerd.
another thing that techs sometimes do (more like did) is run around and reflow all the solder joints. occasionally, you get what's called a cold solder joint with stress fractures and high impedance. but with newer surface mount components, I'm not sure this will be an option for you.
Kurdt's links look useful.
Be sure to use a big enough Isolation Transformer when working with exposed AC Mains (and higher voltages!) like in TVs. And be sure your electronics friend can explain to you why an Iso is important...
Also beware of high voltages being held on capacitors -- they can surprise you long after the TV is turned off. Do you have a SAMS Photofacts for the TV? You really need one of those before you start digging into the TV. Also, what is the anode voltage for the projection CRTs?
EDIT -- Hmmm, doesn't seem to have a SAMS Photofacts edition for that TV... Toshiba may not be cooperating...
http://www.samswebsite.com/description.asp?ID=Photofact
Cool. I'm finding the same links.
If you can eyeball and find a defective component sometimes you can replace it. Heating soldered connections and resoldering a new component can easily ruin adjacent components...so use a modest size soldering appliance.
I'm not expert either, but it looks like the projection illumination buld is still good..those can be quite expensive...if you buy a replacement circuit board and you open the package you'll own it...so check if the board you suspect is an expensive one...testing circuit boards on your own is typically not easy...if you have specs and test values and enough spare time and interest, it's not so bad.
9K
10K
  • · Replies 32 ·
17K
17K
