Thread Closed
Train Moving pulling two boxcars
Share Thread
Feb5-09, 01:16 PM   #1
A train consists of a 4000 kg locomotive pulling two loaded boxcars, the first with a mass of 12,000 kg and the second with a mass of 16,000 kg. Assume that the boxcar wheels roll without friction and ignore aerodynamics. The acceleration of the train is 0.4 m/s2.
With what force strength, in Newtons, does the first boxcar pull on the last boxcar?
2. Relevant equations
F=ma
3. The attempt at a solution
I thought the mass should be the total of the last two boxcars which would be 12000 plus 16,000 =28,000 so I tried 28,000*0.4m/s^2 which came out to 11,200 which is obviously wrong the answer to the question should be 6E3, what am I doing wrong?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb5-09, 01:58 PM   #2
Recognitions:
Homework Helper Homework Help
If the train is accelerating then what force is accelerating just the last car?
Feb5-09, 02:09 PM   #3
Recognitions:
Gold Membership Gold Member
Quote by Jordash View Post
F=ma
You should be using Free Body Diagrams (FBD). What you have calculated is the the pulling force of the engine on the first boxcar, not the pulling force of the first boxcar on the last boxcar. The easiest way to do this problem is to look at the last boxcar only in a FBD of that last boxcar. Identify the force acting on it, and solve for its value using Newton 2.
Thread Closed
Tags
force, kinetics, motion, pulling
Similar discussions for: Train Moving pulling two boxcars
Thread Forum Replies
Moving train problem Introductory Physics Homework 4
Train pulling caboose - forces and friction Introductory Physics Homework 7
If a train is moving 5mph? General Physics 9
About a bee flying inside a moving train Introductory Physics Homework 26
Temporal distortion of a moving train Special & General Relativity 27
